K.V. Collucci said:Your unit is what they call a hard wired smoke detector. Most likely there is a control panel somewhere in the home (probably near front door). This panel is monitored by a central station alarm. The panel is wired to you phone line which is hooked up to the CSA. If a detector goes off it will notify the CSA who will in turn notify the fire dept. If you do not have a control panel it is just a hard wired unit that works as a normal unit only it doesn't need batteries as it runs off AC current. Did the previous owners tell you anything about it when you bought it?
