I've been building lock back folders and trying to find the best way for smooth opening and closing of the blade. Mostly I've tried using a 1/8" pivot pin with using no washers and using washers. Without washers the blade will open and close smoothly however the pivot pin has to be a bit loose and so there is a slight amount of blade play. The nylotron washers I have are approx. 16 thousands each so to use them I have to mill out that amount of space from each liner. I get no blade play but the blade is stiff to open and close. Would using a larger pivot pin make a difference. Is there some other way to mount the blade so that it will open or close more freely. Any help would be most appreciated. Thanks. Dave
