just like cue making in that aspect. I bought a lath then called a guy to get some wood. he let me know I screwed up. I should have bought the wood 5 years before the lathe lol.Miles Gilmer has great wood. They are professionals, and just like Mark, won't sell you junk....because they want you back again as a customer.
They aren't cheap, but the quality has always been very high in everything I bought from them. Tell them what you want the woods you by for so they know what to look for in selection.
Snakewood is beautiful, but has to be worked carefully.
It is best to let the wood sit on the shelf for six months to a year before you even use it as a knife handle. Allow it to normalize with your climate, and to continue any dryng needed.
It is not for you if you don't have a VS grinder. If you don't have VS...... only work it by hand. A fast grinder will destroy it....guaranteed!
Use fresh belts and abrasives and NEVER get it hot. As Mark said, have a bottle of thin CA on hand, and flood every crack before working the wood. As you work it, check for new cracks al the time, flood these as you find them. Once the handle is shaped to the final shape at 400 grit, flood the entire handle and let cure for a day. Sand off by hand with 400 grit paper and repeat a time or two. Every time, sand all the surface resin off. You only want the wood showing, not any CA glue. Once those sealing processes are done, you can sand snakewood to 2500 grit and it will shine like glass. The finer the grit and more thorough the sanding job, the more 3-D the snakeskin look is. You are not done yet, though. Set the knife in a normal room temperature place for a month. After leaving it alone for that time, inspect carefully (a magnifier is good here), and look for new cracks or checking. Flood and fill as needed...and set aside for a second month. If all is well after that, the knife can be put out for sale or put in use. Check every 3-6 months for cracks, as they can show up over a very long period.
