Snap-It or Remote Release, which one?
Architect
I need advice. I am going to get either the Snap-It or Remote Release. I know I do not need both.
I am having a hard time deciding because it looks to me like the Snap-It hook and latch might be "in the way" after opening the blade.
The Remote Release seems like it will take a two motion release to de-shackle and the extend the blade. This takes away a little bit from the Spydieness of the one-hand quick open.
I generally will use the knife on camping trips. It will also see the very occasional sailing/snorkeling trip as well as the occasional snowmobiling adventure.
Thanks for any help. I posted also on Spyder forum, so please ignore the redundancy.
Snap-it is best for fast hooking or unhooking, but not good if hooking to large diameter object such as a rope. The rope can lodge behind the snap. Then it may take both hands to unhook.
Remote Release is slower to hook and unhook but easier to release from large diameter items. Also, in dirty environments the Remote Release mechanism can get fouled. That is, dirt or mud in the spring/slide area.
It's really up to your needs. If none of the above is a problem, I would opt for the Remote Release.
I tried both before settling on the remote release. I agree that it might get gunked up, but I haven't had a problem yet. I attach it to a belt loop. When you use the remote release your hand is automatically in the proper position to open the blade. Releasing and opening are one movement. Its an overlooked design IMO.
G.
Thanx John, Gary. The "Snap-It" is currently available only in a sheepfoot blade for 2001. The "Remote" might not make it to the 2002 line up (I didn't say that );)
sal
Architect:
Try "none of the above." Pick your favorite Spydie and get a Mike Sastre sheath ( www.rivercitysheaths.com ) for it. The implementation of high-grade Concealex (& possibly a lanyard) for neck, belt, or pack strap carry, has made both the Snap-It and Remote Release obsolete.
