Snaps Question
I'm looking for snaps that are attached by screw. I have them on a couple of iwb holsters from milt sparks and kramer leather, the snap's cap is attached with a setter but the male part of the base is attached with a screw to be able to change it out. Any help will be appreciated.
Thanks
Cazio
There are 2 types of snaps. One with prongs, and the other with holes that are meant to be rivetted in place. If you know the thread details in the sheath, then a screw with the same thread will attach the "stud" part of the snap. You may have to reduce the head size on the screw with a grinder or lathe if you have one.
The studs are usually a line 95 size and either regular or "pull-the-dot"
Hope this helps.
You can also find them with screw included - look at auto parts stores since they use them for attaching fabric tonneau tops to pickup beds...
