Snow & Nealley single bit
DdjmhentbsQkKMXw7
EVRip9B9R3zyxcicA
Z6KfpA1tByuxBFpk7
Hi all - just joined the forum after doing some searching online surrounding a S&N single bit I picked up a few days ago. Was hoping someone can enlighten me a little on the approximate manufacture date. Came with a non original 36” handle that I think I can salvage and remount, unless there is a better length to put on these size heads.
It’s stamped as 3 3/4 on the bottom of the poll. Bit is 4 3/8 long (tall?), length just under 7 inches.
Any info is appreciated!
https://photos.app.goo.gl/Z6KfpA1tByuxBFpk7
https://photos.app.goo.gl/UtyZ9r2bBPLYeMjP8
https://photos.app.goo.gl/zQ8ds9YKLHmjheiQ9
Happy New Year, Andrew.
You'll need to upgrade your Membership to at least Gold (it's worth it!) before you can solicit information, pricing, etc.
Cheers
Cheers
I don't know if things have changed, but as I recall you only needed a gold membership to ask for a price on something or sell it, not just to ask a question. Yankee Josh Yankee Josh is the resident old N.E. axe guy, maybe he'll be able to give you an approximate date of manufacturing.
Awesome. Yes, interested in information on it, not price. I haven’t been able to find anything on these 3 3/4 lb heads - most of the searching pulls up the newer 3.5 lb heads. I’m also assuming it’s a felling head, but wasn’t sure if that was what they were marketed as, or if it was something else.
Hello Andrew,
It's true soliciting info is fine. I daresay what the forum is all about! But still a gold membership and a new contributor is a good thing too. :D
I can tell yours has an overlaid bit which does indeed make it older. But how much older we don't know.
I've asked some questions of a gentleman that used to work for S&N for twenty years. But his employment was after they had switched to all tool steel and they had the giant drop forge hammers.
According to him they acquired those big hammers in 1972. But I believe it was earlier than that when they switched to mono steel construction.
I know the date October 1st 1952 has some significance to the company as they stamped some of their axes with this date. But we don't yet know what that date signifies.
I have older examples like yours. 3-3/4lb was a more common weight back then. The long and short of it is it's hard to say old your axe is. I'd guess possibly the 40's or earlier. But that's just a guess, so take it with a grain of salt.
Does yours have a small "dot" or indentation right in front of the eye on the bottom?
As far as handle length, it's all up to what's comfortable for you and of course what you can find. You can find some good helves at home depot usually if you dig through the bin. They will be 36" though.
Sorry I couldn't be more precise. S&N is not easily giving up its secrets.
Here's the two better photos you posted;
That helps a lot - I had no idea about the differences in forging processes from one period to another. I’m going to try and remount on the handle it had, new wedge, sand off the shiny part of the finish and see if I can get it to take some linseed oil. I’ll also take a look this afternoon for the mark you’re talking about.
Didn’t see any mark near the eye like you were talking about. Got the head remounted, handle sanded down a little, first coat of oil on it.
hXaqkAEK5R6JafFg9
Got it cleaned up and rehung on the same handle. I think I’d prefer about an inch or two shorter, but it’s staying this way for the foreseeable future.
Picked up a couple more tonight - I think one is a plumb permabond hatchet, but there isn’t any label or stamp on it. Any thoughts from you all? Also another about 3.5 lb single bit with no markings, but the remnants of a foil label, I think. If anyone recognizes it, I’d be super stoked.
https://photos.app.goo.gl/ZGGqm1GSkq87ANmn8
ZGGqm1GSkq87ANmn8
Hmm, it appears to be a wedge/maine pattern if I recall correctly, made in the early 1900's and yes, you can use it for felling, bucking, and splitting.
Just Wedge pattern. A Maine pattern would have a slight curve to the jawline. The Maine, Wedge, and Half Wedge patterns are distinct from one another.
