- Sep 28, 2014
It's a concrete brick. It was $0.51, including tax, at the home center. It's 8x4", which means it's really 7.5x3.5". (I never knew that masonry dimensions were lies, just like lumber.) Anyway, I brought it home and gave it a try lapping the coarse side of my Crystolon stone, and it did a fantastic job! It clogged pretty quickly, since the grit size is actually pretty close to the stone, and it picked up a lot of oil, but I used all four of the long surfaces and got the job done. Next time I will start on the sides, since they are rougher and really get with the program, while the top and bottom are smoother and flatter, and better for final flattening. I'll throw in some dish soap to help with the oil next time as well.
That economy stone was glazed up pretty good before I started, and after three minutes on that brick, it was like new again. I used it to even up the angles on the pen blade of my new Case jackknife, and it went through that CV in no time!
I'll need to get a second one, to use in de-glazing the first. I figure if I use a little soapy water between them, and alternate multiple surfaces, I'll end up with everything reasonably flat. Plus, I can keep these right by my sharpening bench, and the Mrs. won't get hot about any unsightly lapping marks on the front walk. 😗
I think I'm probably gonna do this to my Crystolon pretty often just to keep it cutting fast. As cheap as it is, I don't care if I wear it out more quickly, and it works SO MUCH BETTER.
And no, I will not lap my waterstones on it, I promise. 😁
