So I've been "planning" on getting into knife making for a long time. You know, "waiting" until I have a forge and a drill press and all that. That's kind of a big wait, and I decided I wanted to try to get my feet wet before then so I'm going to buy a bench vise and some hand tools and some steel stock and start cutting out a knife.
I haven't really made a lot of design choices or anything yet because I'm trying to familiarize myself with what the overall process will be, but I want to make a 4" fully-fixed one piece fixed blade. I figure making it one piece will allow me to cheat in not needing to make scales, and still get some experience in the meantime--plus I like one-piece knives.
So anyway, here's what I'm thinking I'll do...
1. Find some steel stock to use. I'll probably want it about .250" x 1.25" since from what I've seen that's a pretty common size available.
2. Cut out a "blank" of my knife design using a hacksaw and handfiles. I'll probably do a lot of pieces in wood until I get a "template" to follow.
3. Cut out the bevel leaving some room for the edge bevel itself--heard this was important, makes sense. I'm just going to have a swedge on the spine and then a flat grind to the edge, so I think a rather coarse file will work well for that.
4. Smooth out the corners on the handle. I'll probably just file in some chamfers at 45 degrees, and then round them over with sandpaper.
5. Smooth the whole thing down with some sandpaper. I saw a thread suggest stopping at 400, but is this just before HT, or in general? I want a pretty high polish.
6. Heat treat (No plans for this yet)
7. File in jimping and grip on the handle and then do any more polishing if I have to wait until this point.
8. Finally profile and sharpen an edge onto the end of my primary bevel.
I've made a lot of various tools going to school for machine technology, so I'm not really worried about most of the metal work and look forward to figuring that out, but what I"m wondering about is the choice of steel and the heat treat process.
From what I've seen there are ways to build your own furnace, but in another thread ( sorry I can't remember which ) a user seemed like they were suggesting using a conventional oven to HT 1095. Is that even possible? In any case, my steel for this knife will mostly be motivated by how capable I will be of heat treating it. I believe someone in the same thread suggested 5160, and that seems like it would do just fine for what I'd want to use the knife for--right now I'm mostly just focused on getting my foot in the door with some experience.
Only problem is I probably won't be able to have access to a furnace of any sort, even a home-made one. I've heard many people talk about sending knives to various makers for heat-treating though, so is this an option until I can get into the position of being able to HT myself?
Anyway, I think I've got the general process thought out pretty well, is there anything I'm missing? I'll have a whole bunch to think about with attaching scales later on down the road, but for now I'm just going to focus on one-piece fixed blades.
