- Feb 27, 2011
Which is it? Im wanting a double-bit for work, and a velvicu for myself. I find it hard to swallow that axe heads would be cast.
Keech casts racing axes. They have some specially developed process though.
ok guys i am a competitive woodchopper from Queensland in Australia and i can lay all your questions to rest the reason for different hardness in the steels and axes is of 2 major contributing factors.
1) the composition of the steel it is made with the carbon content ECT
2)
A) the process used to make the axe Eg. the keech and keesteel axes are cast axes where the molten steel is poured into casts much like some other older brands and the keech steel used is K2 steel making is extremely hard infact hard enough to cut other steel
B)the tuatahi are forged axes meaning they start from a block of steel which is then heated and compacted to a base shape making is some what harder than when it started in the tuatahi factory still done carfully by hand as well as some other high end makes but rare by hand in our days but usually done in one or two hits now by a machine press as to make it quick then the edge is tempered this is what most cheap store bought axes are now as it can be done very and cheaply it tempering is not exact the results can be absolute rubbish like so many store bought axes
C)the third way is milling which is also done by some top end axe makes IE Mr Mick Osborne who makes Osborne racing axes it is first started with just a single block of tool steel and the the block is milled away by diamond bits and cnc machines to create the axe head
D) the final way is a combination of 2 or more such as the tuatahi 2 piece axe where the eye and pole of the axe is good quality steel but not hardened but the head there is no blade is made seperaltly then screwed on or cold weld ECT
Bridger,
Have you worked with Keech axes before? I was working on one recently and thought something was unusual about the steel... I wondered if it was cast but thought it was unlikely. I found the head extremely difficult to sharpen with a file. Wondering if there is any correlation?
thanks
wdmn
Does anyone know how to go about sharpening a Keesteel head? It actually broke a couple of teeth on a new grobet file (standard of 60-62 HRc)...
So moisten the metal cutting wheel on a grinder, and just take it a few passes at a time? Or do you mean a water cooled traditional grinder?
