Bühlmann
North Lake Forge
- Jan 6, 2022
I understand that, which is why it seems odd that it split not along a spalt line but rather the wood between spalt lines.The process of spalting in wood is from decay by fungus. Stabilizing is not going to make a weakend wood tougher.
It was an outfit from AZ...I have no idea what they use, but their reputation suggests that it would be a recognized stabilizing product and process. I get that crosscut wood is not the strongest, I just didn't expect a 1.00"+ block to fail from a drop of three feet off of the ground. Live & learn I guess.Cross cutting against the grain is the most structurally weak way to cut blocks. You can get beautiful figure, but it comes at the cost of diminished strength.
Professional stabilizing companies like K&G will make spalted wood much tougher.
Who stabilized the wood and what stabilant was used?
Chuck
I would have expected that stabilization would have given cross cut blocks better strength. Correct me if I’m wrong, but it’s essentially impregnating the block with, effectively, a glue- something that bonds substances.Professional stabilizing companies like K&G will make spalted wood much tougher.
The issue with spalted wood is that it starts to go “punky”, or soft between the spalt line, like a sponge, if left too long. The stabilization will make that hard, but not overly tougher, unfortunately.I understand that, which is why it seems odd that it split not along a spalt line but rather the wood between spalt lines.
This is a fantastic way to keep this block useable still.It's broken at a really nice angle. Perhaps consider grinding them flat and inserting some kind of interesting spacer material to make it look intentional? Lemons/lemonade?
The burn comment was a joke....I wouldn’t burn them. After glue and pinning to handle, they will be fine.
You can actually glue those together with a CA glue and if done properly will look right.
Crosscut and highly figured woods are weaker by nature. I always have to handle them very carefully during all steps. I dropped a pretty much completely finished box elder burl scale from less than 3 ft and it cracked. That sucked. I glue it together and finished the knife.
It is my personal knife and was a test knife and the scale is still fine.
Just food for thought.
Yeah, it's not the end of the world-type break. I was just surprised, that's all. I can definitely work with both pieces independently. I think I simply learned that they'll need to be laminated to a beefy liner of micarta or G10 for me to feel good about putting them on as scales. I've been forged over time and tribulations to eat lemons for breakfast!It's broken at a really nice angle. Perhaps consider grinding them flat and inserting some kind of interesting spacer material to make it look intentional? Lemons/lemonade?
BTW, is that another crack adjacent to the break on the smaller piece?
Totally went over my head. Haha.The burn comment was a joke....![]()
That is true. I misspoke. It doesn’t make it much stronger though. If I drop a piece of spalted spongy unstabilized wood on the floor, it won’t break.Professional stabilizing does make spalted wood tougher and harder. I learned this by processing literally thousands of blocks of spalted wood.
Chuck
