I want to finally get going making some knives for myself. Planning on doing stock removal from spring steel. Some dagger and some chopper type.
Planning on keeping construction pretty simple, just some full tang type w/ handle slabs attached w/ counter sunk screws into tapped holes in the tang. Guards would be integral to the tang. Prolly some home DIY bake on finish.
I have a 2x42 grinder and a table top drill press and an angle grinder w/ cut off wheel for cutting out blanks, got a box of various belts. I also have a buffer unit w/ those razor sharp paper wheels for putting on a final edge. Oh, I also have these drum sander type things that go in the drill press and will sand a radius, and I have a dremmel tool.
Here is what I can come up w/ as needing:
-scribe
-center scribe
-dykem or some die for marking w/ said scribes
-handle slabs
-flat head socket screws and appropriate drills and taps
-some sort of bake on finish stuff.
-kydex, kydex rivets and the anvils for the rivets. (I already got heat gun)
I got another thread specifically asking about tempering/Heat treatment?
Thanks.
-scribe
-center scribe
-handle slabs
Thanks.
