Mike,I wanted to make sure you understood Kevin and mete.
You will bring your forge or oven to 1475-1500F and when that temperature is stable you will introduce the blade. When the temperature returns to the desired point again,start timing.What Keven was saying is that when many people say "soak for 10 min" , the first 3 to 5 minutes were probably needed to get the temp back up to critical ( the actual soak will be 5min.).The time at critical temp is the time that counts toward dissolving the carbides and making austenite.If you stuck it into the cold oven and let it heat up slowly for a long time,you would most likely pit the blade,and get a lot of decarb,since that starts at around 1275F.
As to your last post, yes it is easier to learn HT on mono steels and similar mix billets.O-1,1084,W-1 are all easy to do.1095 produces a really nice blade,but is a little trickier in that it has to get into the quench fast and has to have a fast speed quenchant.
