socom elite auto dissasembly
  • Thread starter Thread starter w
  • Start date Start date
w
I just couldn`t stand it. I had to take my elite auto apart just to see the insides. I have never taken an auto apart so I was kind of leary about it. I have taken many benchmades apart before but no autos. At any rate it was one of the easiest knives to take apart that I have ever done. The screws were all very tight and since I figured they had locktite on them I got the hairdryer and heated them up before I took them out. The knife was put together with so much precision that I was very impressed. I mean it looks just as good inside as it does outside. Kind of like a swisss watch. I also thought the spring would probably fly when I pulled it apart but it didn`t. It looks like a very heavy duty spring. At any rate I put it back together and it works perfect. The reason I took it apart to start with was that it had a click when you closed it. It no longer has the click so I must have done something but I don`t know what. Must have been a burr or some grit in the action. I just wiped everything down real good and oiled it with rem oil and put it back together again. What a knife. Roger
Roger, I have done this on a regular basis and it is not real difficult. Just prepare your work place and be sure you put down a clean white towel. This helps to keep up with everything. I usually take some 800 grit wet/dry paper and polish the pivot area.I then use Flitz as a final finish. Put back together with some Tuff-glide or Rem oil, and it is ready to go. I use acetone to clean all the parts and a Dremel tool with cotton buffing wheels to polish the button, pivot pin, and stainless bearing. Just be careful on the Microtechs when tightening the screws, THEY ARE EASY TO STRIP.
Art Sigmon
"I can do all things through Christ who strengthens me"
Php. 4:13
