Sodbuster For Dad
I have been looking for a good knife to give to my father, a painter and finish carpenter by trade, to replace his utility knife for some work tasks, and as a knife he can use outside of work. I was looking at sodbusters, and if at all possible, sheepsfoot blade models. I can modify a longer blade, but would prefer not to. I know that GEC's Farm and Field Tools have a sheepsfoot model, but it is out of my budget. I was wondering what brands you folks recommend, and if you could post some pictures as well. I am on a budget of $30, as I am paying. German Eye Brand and Case are the only brands I know of that make quality sodbusters in my price range, but I'm sure you folks know of others. Any input and/or pictures are welcomed, especially side by side comparisons. Thanks.
Happy Holidays,
Connor
The Queen Country Cousin may be a good choice, if sharpened well. Its D2 steel would definitely keep a keen edge for a long time.
I have examples of both German Eye and the Case. I think the Case handle, being rounder, will give less hot spots on the hand during extended use. And Lowe's generally carries them for around $20.
The GEC Hayn' Helper is really the only sodbuster-styled sheepsfoot knife I'm aware of. Well worth the $50, but if you can't swing the extra $20, I understand.
Not really sodbuster styled, but do a search for "Sheffield action lambsfoot knife", (they typically call them lambsfoot in the UK) and you'll find a folding, ABS plastic handled knife with a straight blade. If you're OK with the knife having a bolster, you can find some Joseph Rodgers and Sons and Wrights of Sheffield lambsfoot/sheepsfoot blades for pretty cheap, although you might have to order them from overseas. Also the Otter Webermesser from Germany.
What you mean, I think, is the Otter Hippekniep - that would be the traditional Sodbuster style, but with wood handles and not synthetic. The Otter Webermesser is no Sodbuster/Hippekniep. It has a wharnecliffe mainblade and bolsters. As far as I understand that term - a Soddie/Hippekniep comes with a skinner-blade and without bolsters.
But Otter is a good address to get a Sodbuster/Hippekniep for very low cost and a high value (just my experience ;) )
Happy Holidays,
Connor
Hi Connor,
Add Boker to your possibles list. They make a sodbuster in your price range.
Most painters these days use a lot of waterbase paint. Not to mention waterblasting surfaces to remove old paint. With all that water around, I would aim for a knife with a stainless blade.
I have the Queen Country Cousin, and it is a perfect knife for utility work. I am in the same business and carry that knife in rotation with others. I like the thin slicing profile as I use my pocket knives to sharpen my pencils to a needle point when doing trim. This knife will do pretty much everything you could ask of it out on the job.
I like and agree with the idea of having a steel with some rust resistance. The Queen hits well on that as well with its D2 steel. It takes a good edge and holds it well.
Search this subforum and you will find a lot of info and pics on the different soddies and that style that are available.
Robert
Thanks for the help guys. I am thinking of getting a Queen Country Cousin and having someone create a more usable edge if needed, as I do not have diamond stones to handle the D2. The D2 wil be nice because I won't have to sharpen it as often, and it won't rust easily. I am also thinking of getting a TL-29 to let him test drive; the flathead screwdriver will be handy for electrical plates and popping open paint cans.
Do you still use a utility knife for certain tasks like cutting drywall? Personally, I avoid touching up my knife while working, so I use the utility knife for work that'll kill an edge fast.
Thanks again,
Another recommendation for the Queen CC. :thumbup:
The D2 steel edge will stand up to hard use longer between sharpenings but I wanted to add that the Queen is a smaller sized sodbuster than the "standard" Case and Boker et al.
A great knife though, I love mine despite having "nicer" knives.
Connor, good on you. A knife from a son (or daughter) is a treasure. Sodbusters are super popular for hard work and that should be respected by all means. As others have mentioned, supply stores like Lowes generally have the Case Sodbuster in your price range. That's a good solid bet.
Another tough work knife that is amenable to blade reshaping is the Opinel, which can generally be found in the $15 range in both carbon steel and stainless. I believe many *mart type stores sell a Berkley (the fishing supply name) mini tool like the Leatherman shown here for $5 - $6. I find that to be a super valuable companion to a single blade work knife like a Sodbuster.
Every Day Carry Pairing by Pinnah, on Flickr
A G Russell makes a sodbuster with amazing fit and finish in your price range: the rancher (small sodbuster) and cowboy (larger).
I'm wondering if an opinel might also be a good quality cheap option?
I have been looking for a good knife to give to my father, a painter and finish carpenter by trade, to replace his utility knife for some work tasks, and as a knife he can use outside of work. ..........Happy Holidays,
Connor
As an ex finish carpenter and electrician, I would strongly suggest a knife with a stout sheepsfoot blade.
And a knife that the blade can be pinch opened, because you are constantly opening and closing your knife
Quite honestly, I would not use a Soddie for carpentry work because of the blade shape
The replaceble blade of the Stanley utility knife is like a sheepsfoot
You use the tip for pull cuts to cut against a metal rule or square, or for cutting sheeting of flashing
To mark an angle cut on molding, or marking a length from a rule
All these cuts need the blade shape of the Stanley or a sheepsfoot
So
Klein Tools have a sheepsfoot blade knife with a bail that would definitely fit your bill less than $20
(Klein Coping Type Pocket Knives)
Carbon steel coping type blade 3 inches long (1550-14), with linerlock
or
2 1/4" locking or not
or
A classic electrians knife with a curved-sheepfoot slitting blade and linerlock screwdriver-tip blade (1550-7) , good for painting
Well worth to check it out
(email sent with link to store)
Do not be afraid or reluctant to get a knife with D2 thinking you will need some special diamond equipment. I have two large Ontario sheath knives, several Kershaws, and a few Queens with D2. I sharpen all of them with regular stones. Aluminum oxide, ceramics, and even a touch up now and then on an old Arkansas hard stone I have work just great. No special treatment needed, no precautions warranted, no extra sharpening skills to be learned... nothing. Sharpen as you normally would, then carry on. D2 is a great knife steel, but it certainly isn't anything extraordinary.
The TL 29 is a tested and true knife, but even on the nice ones (Klein with its limited lifetime warranty, and Greenlee for example) have such soft steel I haven't found them acceptable as a good working knife. For its purpose, the TL 29 is hard to beat. Be aware though, that the knife isn't made for doing something like prying off a paint can lid.
I buy my knives for the knife blade, not for the other accessories on it. To each his own; if I were to go that route, I would buy some kind of multitool.
Thanks again,
I absolutely do. For cutting drywall (nothing works better than a utility knife for that!), insulation, cutting hardened old sealants, stripping wires, etc., I use a utility bladed knife. That is what they are for. My Queen CC or whatever other work knife I have in my pocket sharpens my pencils, trims moldings as needed for fit, cuts wood plugs for screw hole fillers when hanging new doors, cleans up mortises for hinges, and on and on. Anything that requires cutting and slicing wood or other things you would use a regular pocket knife to do. It might also halve an orange, and notch my cigar on any given day. I use that knife as a pocket knife should be used, as a cutting instrument. The utility knife gets all the nasty work, along with the stuff it was actually designed to do.
I don't touch up my CC but once a week unless I accidentally do something like hit a hidden staple or cut something that was much harder than anticipated. I might change utility blades once a day.
Robert
Thanks again to those who have responded.
I have thought about the TL-29, and have decided that getting a small keychain tool like a Prybaby would be better. I won't be buying a Prybaby as they are very expensive, but will find a quality maker who has similar items for less (I am contacting Daniel Fairly first). I am 99% sure that I will buy the Queen CC with amber handles.
Pinnah, my mother and I will be paying for a LM for his birthday in March, I am still thinking about which model I will get, but am sure that I want a pocket sized or smaller. Thanks again for all of the input and help.
Connor
