SOG Flash II Conversion to Assisted + Auto Tutorial
Video:
http://www.filecoast.com/?pg=file&c1=2317965264&c2=H22PBv2E
Those of you mechanically-minded will probably figure it out on your own. So this is for those who need a little inspiration.
The knife utilizes a coil spring as the drive mechanism and a piston with a linear (coil) spring as a detent and lock. The coil spring doesn't need to be touched and in fact is a little difficult to reinstall. The work will be done on the piston and the scales.
A top down look on the piston and the thumb button:
It can be seen that the thumb button has a notch that engages the piston in pulling only, that is it is free-sliding in the forward direction.
Now the piston requires different stroke lengths to overcome the detent and to unlock the blade (close the blade). Specifically, the stroke length required to overcome the detent is greater than that required to unlock the blade. The slot in the scale to accommadate the thumb button is for obvious reasons only long enough to effect the latter. The idea is to increase the amount that the thumb button can be pulled back, and this can be solely done by lengthing the slot toward the end of the handle by maybe 2.5 or 3 mm. Just file away lengthening the slot toward the end of the handle. Note that on the inside of the scale the thumb button travels in a provided channel. This will eventually limit the movement of the thumb button unless you lengthen this too. So to sum up you can add the Auto function by cutting the slot provided for the handle a little longer towards the end of the handle.
You can decrease the amount you need to lengthen the slot (to a degree that you don't need to lengthen the recessed channel on the inside of the scale) if you fix the thumb button to the piston with some epoxy such that it is maybe a millimetre forward of the position that it would normally engage the piston. This is the approach I took, so I created almost a mm of extra stroke length with the epoxy and additional 1.5 - 2 mm by lengthening the slot. Since now the thumb button and the piston are fixed together whereas before they were free-sliding parts, some additional filework on the slot might be required as it possible that the fit is tight.
PS: I'd except SOG being an American company to use English units, but a 2mm hex wrench happens to fit perfectly. All the screw heads are one size.
Video:
