SOG MT Mods
Since I received my Powerlock (EOD 2.0 V-Cutter), I've always intended to replace the half/half blade with the fully serrated model. Looking through the replacement parts, I'd like to also add the wire stripper and C-4 spike, mainly because I get everything else covered in my SAK and would like the extra tools. The question is, can I fit all 3 versions in the unit? I guess the long tools that I want to keep are the file and saw, the v-cutter is nice to have, but the blade could be sacrificed if I needed to.
Assuming this is possible, what would you consider dropping out? it does appear there is a 1-unit spacer next to the 1/4" drive, so maybe the spike can fit in there.
I think..... you can get four long thin tools in there. So you'll have to pick which you want, probably have to go bladeless.
I'm not sure where the spike sits, if its a middle tool, then you should be okay. Also I feel like the spike is a double wide like the 1/4 drive? I found that planning was pointless, you kinda just keep trying combos until it works. B
