SOG seal 2000 dimensions
I would have preferred asking this in the SOG specific forum, but I guess I can’t post there, forgive me.
The SOG seal 2000 isn’t made anymore, and I would like to commission a custom version, just to get my preferred steel. I do have some of the specs, such as blade thickness and length, and handle length, but I would like some more specific dimensions, as I want to clone it as closely as possible, at least for the stuff I want to keep the same, which is most of it, and make the custom knife maker’s job easier. Anyone have one that they can measure with calipers and micrometers? I would like to know blade width, handle width and thickness, as well as the length of the clip and if possible, the height of all the grinds. The 2000 also sort of has a guard on it, but it’s part of the handle material, and I would like to commission it with a metal guard, so the width and thickness of the guard would also be helpful as well. I understand if you guys can’t come up with it, as I’m asking for everything short of an actual blueprint. (I’ll take that if you have it, though) I also apologize again if this is the wrong forum.
I thought i had one, but I dont as it's a team elite. so different dimensions and grind, steel etc. found this on the arizona knife reseller site.....
don't know how accurate it is, but I assume they measured it to get these .....
"Seal 2000 Fighter by SOG Knives has a grey coated partially serrated clip point blade with hidden tang, .236" blade stock and 1.378" blade depth."
Blade depth is another term for the blade width, correct?
Thanks for the help. I still need more dimensions, but that’s a big one out of the way.
yes Sir.
someone has a seal 2000 and calipers and will come along and get ya info ya lookin for. when they show up ask them to check those specs I found online....measure twice cut once routine.....
