Most I have looked at do have a slight amount, any tighter and they would not open properly out of the box I don't think.
Having said that, I tune mine, and most that want a "really tight" blade does.
A 5/64th allen head will tighten "usually" if the loctite in the pivot is not too tight, (usually not).
I have tuned all mine and my sons Flash IIs and they work perfectly.
To tune: Insert allen into right side of pivot, turn clock wise a tiny bit, now try to open blade, if it opens slow, it should be close to being where you want it to be.
Now check your side to side play, it should be almost all gone.
Now add a couple drops of "light" oil into pivot area, open several times until blades snaps open, this should do it.
All the above "could" void your warranty, so if you think you can not do it correctly, send it to SOG and ask if they can correct the side to side blade play.
I'm sure they will help if they can.
Robbie Roberson
