Are all SOG tantos chisel ground all the way to the primary point?
I had mine ground to 16 degrees removing the serrations between the choil and the seconday point and the plain edge between the secondary and primary point.
The way it was ground at the factory was uneven and after it was ground and sharpened the bevel was evened up on both sides as best as is reasonable. It was still not the same all the way on both sides and the edge was in the middle most of the way but in the primary point the edge is still kind of over to where the chisel edge side was.
Has anyone else had problems regrinding a SOG tanto?
