SOG Tech Bowie (Minor Issues)
Hello all. I have lurked these forums for a little while, but I am finally registered and posting. I appreciate the advice I have received here, so far. :)
In the past few years, I have been getting into hunting and more outdoorsy activities like hiking on the Appalachian, camping, ect. I have always been the outdoorsman type, but I never really invested in good gear. About a year ago, I decided it was time to start picking out some better gear - starting with a quality knife to fit my needs. I did my research and decided on a few things that I needed in a knife:
1) Full tang and quality carbon/stainless steel and a non-corrosive finish. I want this thing to hold an edge.
2) No serrations. I just don’t like them. Plus it’s easier to keep the blade sharp.
3) A solid grip - with no chance of slipping. This includes hand guards.
4) I wanted a knife that was long and heavy enough to chop wood and take some abuse - but not too long so that I have control with it.
5) A solid butt for hammering/staking.
6) A knife that I could use in a defensive situation if the need arose (against a person or wildlife). I thought about pig hunting for this instance. If I were going to shank a wild boar, I wanted a piercing point, and again, a solid-no-slip grip.
Keep in mind, that I live in the east. It is cold, hot, wet, sticky, icy, ect. There are wild animals to take and defend against. Trees are small and soft enough to cut with a knife - an axe is not a must. Firewood is. A shelter is. Potentially, I could use this blade in lowlands, highlands, coastlines, swamps, but mostly in the piedmont.
So... Taking all of those things into consideration, I purchased a SOG Tech Bowie. It has quality steel, a sharp edge, a great grip, medium length, a piercing tip, and a solid butt. The kydex sheath also drains out water if the blade gets soaked. The blade design may look a little thin towards the tip, to some, but I liked it for what I intended to use it for. The point on the back of the blade looked like it could come in handy somehow. So far, it has only helped me crack open coconuts - in which it worked flawlessly, lol. I don’t think prying is a job that I would need this knife for, so again, the tip design should work for me. Best of all, the company offered a lifetime warranty on the knife. How can you beat that?
Recently, I have been putting this knife to use. Sure, it looks beautiful with its shiny black finish… I think it will look a lot nicer with some wear and tear, though! My property has a creek and is mostly in the bottomlands. I used the bowie to chop bamboo, cut down some saplings, shave some bark, and splinter some wood to make a fire. No jobs that were too strenuous on the blade. The knife was working great. This handle truly is slip-proof. It is practically glued to my hand and feels ergonomically, great. The blade also held its edge like a champ. I know I would feel completely comfortable while pig hunting with this knife. I really thought that I had the perfect knife to fulfill my needs.
…But (problem 1) the button on the rubber retention strap, on the sheath, broke. I don’t even know where it went, but now the knife is not held closely to the body when in the sheath. It sort of… bounces around. The kydex sheath still holds the knife with a reassuring *clamp* when sheathed. It isn’t coming out. It just… isn’t held as tightly. No big deal, I thought. It’s just a button, and I’ll probably just fix it, myself. I won’t hold it against the knife, which so far, I have been in love with.
So another day, I decide to build another campfire behind the house. My roommates, friends, girlfriends, ect. like to hang out by the fire pit. Instead of the usual burning of leftover boxes to start the thing, I decide to use my knife to try to get a “natural” fire going. I find a small log that has been split and start to splinter the wood along the grain for some good tinder. All of the sudden, (problem 2) the blade gets loose… What the heck… Well, the cool looking, tooled nut that attaches the tang to the hilt has come loose. As you can see here:
Now, I have been loving this knife, so far. I didn’t mind the button breaking so much, but this loose handle would have been a big deal in a survival situation. This is also a $200.00 knife. It is supposed to be able to take a real beating. I do understand that the knife is definitely NOT broken. It has simply malfunctioned. I wrote an email to SOG and asked about these issues and their warranty on this knife. I asked if these were some common issues that this model incurred. I am anxiously awaiting their response. I do want to fairly finish this review – especially after dealing with this companies customer service. Hopefully, I will have a great experience and can continue to fulfill a positive review of this product. At this point, unfortunately, I am a little hesitant to recommend this knife as a blade that you could bet your life on, though. What I am hoping is that I received a knife that wasn't fully seated with that odd little nut. Has anyone here had similar issues with SOG knives? It has to be a rarity, since they all seem to be constructed similarly (I hope).
I had a Tech Bowie for a short time and it had the same problem. The whole grip assembly came loose so I put it back together and tightened down the bolt. In my opinion, poor form from the factory. It shouldn't come apart so easily considering I never took it out of the house, this happened in my kitchen :(
What I do like in the SOG line up is the quality of the "old" series of models made in Japan. Nowadays I have 2 Pup Elites and one Sterile Bowie from the early 1990's. That will be it for the SOG products.
Yes, in the last 3-4 years SOG has started cutting corners on their designs. I have a Spec-Elite II. In essence its a 5 inch blade folder that would otherwise be absolute perfection, save for that it's metal liners are waaay too thin and the handle is made of thin zytel too. You can squeeze the damn knife in your hands and feel the handle give way. Not exactly deserving of a brand name that stands for Special Operations Group. I've never had issues with their steels however. They've always taken a good edge on a sharpmaker.
You said you wanted:
"1) Full tang and quality carbon/stainless steel and a non-corrosive finish. I want this thing to hold an edge.
6) A knife that I could use in a defensive situation if the need arose (against a person or wildlife). I thought about pig hunting for this instance. If I were going to shank a wild boar, I wanted a piercing point, and again, a solid-no-slip grip."
1) This isn't a full tang knife, its a stick tang. Carbon steel would have been a better choice for your uses
4) A 6inch blade is hardly appropriate for chopping. These are fighters, not meant to be beaten on wood.
5) The butt on these isn't intended for hammering
So essentially this really isn't the best tool for the job.
That being said contact SOG's warranty department and they should help you.
Hi,
I'm sorry to hear about your experiences with your knife. The nut is known as a spanner-nut, & yes, it can be tightened manually. It IS a good design, the nut allows the tension to be tightened which ALSO allows the handle to be temporarily removed so that ALL areas of the knife may be cleaned & servived thoroughly. If the tension is an issue, send the knife into SOG's
repair department, they will tighten it for you. Ask them what tool to use. That is a Fighting/Utility-knife. It's made for both, though optimal for neither. The "Optimal' fighting-knife is naturally a dagger, with half-serrations (such as the Daggert or Desert-Dagger for example), the best "Survival" knife is the knife you have on you in a bad situation, an "Optimal" utility knife would be the Bk&T Tac-Tool or the SOG Wedge. Or a multi-tool. Your knife should hold up just fine. No, six inches isn't optimal for chopping as is eight or nine, but it should suffice. You may have better success (blade is likely hollow-ground anyway) with more narrow limbs/trees/wood/etc. You may also have better success by using an assisted-method, bending the limb slightly, then applying pressure at the bend or using the "Beaver-Chew" method & cutting around the limb in a circular fashion. Hope that helps.
B2D..
SOG-DOG 1..
Darkwhispers..
SFNC..
Thanks for the replies, everyone. I heard back from SOG, and they will repair the knife and sheath if I ship it to them. They offered to ship it back after the repair. It is good to know that SOG support gets back to you quickly on whatever issues you may be having with one of their knives. Honestly, I am debating just getting some loctite and tightening this spanner-nut (thanks for the technical term, because I had no idea, lol), now that I know that it isn't a major issue. I figure it will actually cost me less money to do it myself - with attaching a new button to the sheath, and I won't have to wait weeks to get it back. This has been a learning experience after purchasing my first specialty knife. In the end, I can't really complain about the knives performance. I just wish I had been a little more technically educated before my purchase. Not because it would have deterred me from purchasing, but because I would have known which issues to watch out for with this particular design.
See there? I told you they support their products! SOG is a great company with great people! That knife you have there is a fine tool, treat it with respect & care & it will last a lifetime!
B2D..
SOG DOG 1..
eather get a seki japan model.or buy a esee or a bark river for 200 dollars you can get a knife made in the usa not stuff from china
