soldering bolsters on lockback
somebody please help me . i'm at the point of severe breakdown. i'm using 304 stainless .040 for liners and 1/8" for bolsters stay brite 1/16" solder and stay silv paste flux and a propane torch . brass is no problem , WHY CAN'T I GET THE STAINLESS TO STICK TOGETHER? what am i doing wrong or am i using the wrong materials or what. i've triedprobably 20 times and can't get it to stick at all. ok now i'm on my knees begging PLEASE HELP ME!!!!!!!!!
Shane ------------------- If you don't have time to do it right the first time, When do you think you'll have time to fix it!!!
I swear by liquid flux! I don't do that much soldering on my knives but when I do, I use low temp 430 degree solder from Sheffields Supply (800-874-7007). They also sell a liquid flux that works well but I buy Tinnemans flux at my local welding supplier.
I like to "tin" everything I solder. In other words, coat the two mating parts with solder first. After you have a solder layer attached to each part, joining them is easy.
Once the metal is clean and at the right temp, you can spread the molten solder around using a Q-tip dipped in the flux. When the mating parts are tinned just clean them again with fine sand paper or scotch brite to remove the burned flux residue. Then put a drop of flux between them and heat slowly. As the solder melts the parts will join together and that's it! Somtimes I will clamp the parts being carefull not to squeeze all the solder out!!
Hope this helps!
Neil
Talonite, new pics, knives in stock!
blackwoodknives.com
Woah, Neil, that has got to be one of the top 5 (if not the best ever) tips of all time here in shop talk! I have always had so much trouble soldering bolsters, that I all but gave up. Now, especially that I'm going to be making folders, your tip will be a huge help to me. Thanks big time on this one Neil!! Take care! Michael
Always think of your fellow knife makers as partners in the search for the perfect blade, not as people trying to compete with you and your work!http://www.nebsnow.com/L6steel
Buzzards gotta eat, same as worms!!!
