Folks, the last couple of times that I have soldered a guard to a finished blade I've come up with quite a mess to clean up. It appears that I have a blackened residue on the blade near the joint area. I presume that the residue is a result of the heated flux. I am soldering the joint on the blade side. The only way that I have been able to remove the residue is to use a fine grit sand paper (400 grit or finer) and then my buffer using a white rouge. However, some of
the blades are satin finished. Once I use the buffing wheel with the white rouge I lose the satin finish for a more polished appearance. I suspect that I may be getting the area way to hot (even though I am taking care to heat slowly from the tang side of the blade) or perhaps this is a common occurrence and I'm just handling the clean-up inappropriately. I've seen illustrations that also show the messy results of soldering but no tips regarding clean-up. Any pointers that someone (or several of you) could bring to my attention? Thanks in advance. >> DeWayne <<
