Some of you might remember my rant about failure
to solder 304 guard to ATS34 blade. Some of youz might've
had truly miserable experience yourself (some to the
tune of going for 8hrs straight
I didn't like 304 for another reason: it is really tough
to work with :thumbdn: . Fortunately, it's little brother: 303,
has sulfur added and is rated @ 70% machinability :thumbup: .
I got me some. McMaster, of course.
So this morning, as 100F weather finally went away,
got into my workshop.Cut off a smallish piece of 303,
sanded on me belt grinder to something like 300 grit.
Into workbench vise it went. Got my stainless flux
(mcmaster, of course - it is weak hydrichloric +
some zinc) and silver solder (same place, 5% silver
+ 95 tin, food safe).
Acid brush, dipped into flux, smeared onto the metal.
Blow torch, warmed it up, from the OTHER side of course,
brought solder wire in contact with metal piece.
Solder melts, beads up and down the metal it goes. Doesn't
wet the darn thing at all ! $*(!&!($*#%&(*@& %(*@#&$ !!!! :barf:
More flux, sanded the solder wire (it looked plenty shiny to me), just in case there were oxides/dirt/oil whatever, same excersize, same result ! :grumpy:
Desperation setting in ...
And this is where a piece of sheetrock falls off the ceiling
and hits me square on the head ! Not really, but I decided
to dip the SOLDER itself into the bottle of flux.
And instant success ! The second I touched that ,wet with flux,
solder wire to the hot 303 metal, the darn thing wet all over the place !!!
I dunno what it does, really - may be there ARE some oxides/oils on the solder
and that causes the bead-up/lack of wetting action. Or, may be, as I heat up
the metal AFTER smearing it with flux, some of the ingridients break down ...
Dunno . But it surely worked great !
