Solid or Serrated??
Dav
Quick question regarding the contact wheels. The wheel is 8" and serrated and is free-wheeling (not the drive wheel).
Pros and Cons (no offense to Jailhack)
Please adise as I have an expensive decision to make based on your input.
Thanks
Dileas Gu Brath
Dav, the solid wheel will grind more smoothly and more slowly. It is also better for finishing. If I had to choose just one, especially getting started, it would be the solid. Later on you might want to get a serrated wheel for hogging steel faster. I use both, but mostly the solid.
Jerry Hossom
www.hossom.com
I used a serrated wheel for almost 4 years then got a smoothy. Didn't realize what I was missin till I put the smoothy on. Man is it nice!!!!
Always think of your fellow knife makers as partners in the search for the perfect blade, not as people trying to compete with you and your work!http://www.nebsnow.com/L6steel
Interesting... I have both but have never tried the smoothy! I was just always happy with the serrated and never thought to try smoothy.
So do I understand correctly that the smoothy will be a better finishing wheel, ie for final polishing?
L6,
Do you rough grind on your smoothy too?
Thanks
Al
Dav,
None taken
My 4" & 8" are both serrated. I am however saving my coins for a smooth 8 or 10" wheel. Jerry is exactly right from what I can tell (at least this time
C.O.'s-"It takes balls to work behind the walls "
