How To Solution to hard-to-open SAK parcel hook
squashracquets
It's been mentioned that the parcel hook can be very hard to open on models where it's located right next to the key ring. Here's a solution.
A few SAK models include a straight pin, but that's not as useful as a safety pin. Clip a safety pin to the key ring. Don't work it through the ring split, just close it around the ring. The spring end of the safety pin (the loop) makes a perfect tool for prying up the parcel hook without even removing it from the key ring. Now you've also added a useful tool to your knife. The pin hangs out of the way and is unlikely to open in your pocket.
Kool idea! I've been lucky enuf to just spray grease on the joint and work it a bit
The grey mini screwdriver that goes onto the corkscrew is perfect to push the parcel hook open. Simply place it along the groove and the mini flathead could push the parcel hook open with ease.
