Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
- Aug 20, 2004
I found some old tools in a machinist chest I bought many years ago in an estate sale. I really never looked at them closely until now. Most of the chest is precision measuring tools and gauges I recognize. Starrett is the main brand. There are taps, dies, and the associated drills for size 0 through 3/4" in both coarse and fine, plus some metric taps/dies. There are a dozen or so really nice tap/die handles the likes of which you don't see anymore. Most of the tools and micrometers are pre-WW2 and some are much older.
In the drawers are some measuring tools that I have an idea what they do, but really only a guess. Maybe some of the machinist fellows will recognizes them.
First, We have a Starrett set of indicator points and the micrometer type holder. It appears that one end fits into some measuring device, and the other end has a chuck to hold the extension tips.. Some of the tips shown are not for this micrometer. The ones that fit the chuck all have a collar and a square end, perhaps for turning it. The ones with no collar seem to fit the next device.
Next, is a Starrett tool I think is for checking runout on a lathe. It appears to fit the cutter holder and the end is gimballed so it can be locked and an indicator pointer swung back and forth. The gimbals can be locked down with thumb screws, as can the angle of the tool. When the gimbal is locked, the tip will swing back and forth on one plane only. I put one of the points from the above set in the chuck on the gimbal.
Last, we have a tool I can't figure out what it does exactly. It clearly measures height/travel/runout in some way. It is a Koch Test Indicator Patent 1906. I can't find much on it except that it seems to be rare. You can see a clear photo of it in the picture of the lathe measuring tool above. One side has a thumb screw to lock it onto san arm, i presume. The other side has a slide cover and an indicator scale. I slid the cover off so you could see the inside mechanism. The post and tab on the end opposite the measuring tip seem to lock into the device it mounts on. The spring loaded plunger rod moves the indicator needle along the scale on the cover slide.
This photo isn't as old as those tools, but it is an old friend of mine. It is a casting torch that runs off acetylene It has a rosebud type tip and creates a crazy large and hot flame. It has many uses in the hot shop as well as melting metals for casting. The tips are quick-change and just snap in the collet. My friend at ARC3 says he has never seen one before. A you can see, it is in prefect condition. I have Prest-o-lite torches and regulators going back to the 1920's. Somewhere I have a 1910 Prest-o-lite gas headlight for a Ford car.
