- Jul 22, 2012
So I'm stumped and I need a third or forth opinion on some engine trouble I'm having. The engine is a Kohler CV20 Command Pro, vertical shaft, VTwin, single barrel carb. If you want further details just ask me.
The engine is mounted to a 2004 Scag Cub ZTR mower and of late its been giving me troubles and its now affecting my work. Since its a V engine, its running 2 magnetos and their run in series. The last one in this series is the cylinder thats acting up.
Problem 1: When throttling up rabidly, then engine cuts out altogether. I have to slowly walk the throttle up.
Problem 2:When starting, engaging blades or anything that requires a load drawn, the #2 piston (I'm calling it...the one with the last in series magneto) cuts out and wont come back until the load is gone.
Any suggestions?? I wont tell you what my conclusions are as to not sway your judgments. I've spent 2 days thinking and working on this but nothing final yet. All I can really do is troubleshoot and clean/visual inspection, it is not my equipment so I do no replacing of parts or diagnosing....I just take care of and use the stuff.
