Cliff Stamp
BANNED
- Oct 5, 1998
This isn't demanding work in general, but do to the very tiny size of the Finch (matchbox) it is in a different class than even most light use knives.
The main issue was at times the entire knife was inside the turkey, cleanup was the main problem. But it was basically able to handle one of the "heaviest" cutting chores in the kitchen with no ill effects.
This was fairly heavy fabric rutting, rubber backed used mats. They were cut to shape to fit a porch. Heavy force was used to do the cuts quickly, again no concerns. The mats were full of grit so the knife did need to be sharpened but just blunting, no visible damage, just a few passes on a medium Spyderco benchstone.
This was harder than the Turkey due to the shorter blade length requiring more strokes but otherwise again no real issue.
This however required a change in method. The knife is too light to chop into the wood so it was press cut. However when the knife was pressed strongly into the wood, the blade started to rotate backwards. So instead of gripping around the handle and pressing into the wood, which put a strong counter torque on the blade, I pressed down on the blade with my thumb which unloaded the lock.
Same thing here. When the handle was used to provide the force the blade really felt like it could have folded back on the lock. So the main driving force was against the blade directly in the thumb ramp. The straight cuts are easy, the round cuts are a bit challenging. The blade was visibly damaged as I cut through the raised round section as it was harder and I did a worse case run. Nothing serious, you would not see it at arms length. Fixed in a couple of minutes on the stones.
Anyway, while a very small knife, the Finch is capable of some large cutting tasks if care is taken to avoid overloading the lock. I'll eventually see just how much force it takes to rotate the blade backwards or separate it from the handle.
-Cliff
-Cliff
