- Nov 15, 2003
Sorry, no pictures but I can at least share my findings.
I do a fair bit of outdoor stuff - anything from day hikes to overnight trips, hunting, fishing, camping and everything in between. I've always had and used knives and found over the last few years that blade/edge geometry seems to make more of a difference (for me anyway) than steel type or hardness, etc when it comes to wood.
So I decided to do a little informal testing. I cut a 2" thick sweetgum sapling and have been letting it dry for a few months now. It stays quite wet in my area so "dry" is a relative term. It's not green anyway, but certainly nothing close to well-seasoned oak or hickory.
Anyway, I have the following knives I used to do some simple notches, just to test how many cuts and how much pressure was needed to push through the bark, wood and heartwood of the sapling:
Bark River Bravo Necker II (CPM-3V, 7" overall, 3.25" blade, .130" thick) w/ Micarta scales - 8 cuts until I reached the heartwood, strong pressure
Bark River Bravo-1 (rampless, A2, 9.065" overall, 4.25" blade, .215" thick) - 3 cuts until I reached the heartwood, very light pressure
Bark River Gunny (rampless, A2, 8.4" overall, 3.775" blade, .156" thick) - 5 cuts until I reached the heartwood, light pressure
Bark River Aurora (CPM-3V, 9.5" overall, 4.5" blade, .170" thick) - 2.5 cuts until I reached the heartwood, very light pressure
Mora 911 (Swedish carbon steel, ? overall, 4" blade, .098" thick) - 6 cuts until I reached the heartwood, light-medium pressure
ESEE Candiru (1095, 5.13" overall, 2" blade, .125" thick) w/ Micarta scales - 15 cuts until I reached the heartwood, very strong pressure
Blind Horse Knives Boattail Scandi (O1, 7.75" overall, 3.25" blade, .125" thick) - 9 cuts until I reached the heartwood, strong pressure
Benchmade RSK Mk1 Ritter Griptilian (S30V, 8.06" overall, 3.44" blade, .115" thick) - 10 cuts until I reached the heartwood, strong pressure
Benchmade Contego (CPM-M4, 9.28" overall, 3.98" blade, .156" thick) - 8 cuts until I reached the heartwood, strong pressure
Wetterlings Wildlife Axe (Swedish carbon steel, 5.5" overall, 2.5" blade, ? thick) - 5 cuts until I reached the heartwood, medium pressure
To make things simple, the convex ground A2 and CPM-3V from Bark River absolutely destroyed everything else I tried. In fact, the Bravo-1 and the Aurora worked so well, I was quite astonished to be honest.
The Wetterlings hatchet with it's convex edge also worked really well, but the less wide Aurora worked the best.
After the two Bark Rivers and the Wetterlings, (well, and after all of the other Bark Rivers), the next best was the Mora. At first I noticed the edge rolled some, but once I re-sharpened it (using a true Scandi grind), it worked well - although nowhere near as well as the Barkies.
The convex grinds seems to work tremendously well in wood, especially in these notch-cutting tests. I also find they work really well stripping bark, making fuzz sticks and other similar tasks. I thought the Scandi grinds would do better, but it seems they only work well if the blade is ground thin. I love the ergonomics of the Boattail Scandi, but it's way too thick to be useful, even compared to the 15 dollar Mora 911. Compared to the Bark River convex edges, even the crazy thick Bravo-1, it's just no comparison.
The Benchmade Ritter in S30V did okay for a folder, but even though it's thin, the v-grind hurt it. I bet if it was convexed, it would do really well. The Contego in CPM-M4 did pretty good even with it's v-grind. I think that M4 is good stuff and might convex that one as well.
I love Rowan's heat treat on TOPS and ESEE knives and the Candiru is no exception. But it's so small, it took an immense amount of pressure just to get in the wood good, and the v-grind hurt it. It did keep it's edge really well though, no rolling or chipping at all and still shaving sharp afterwards.
Folks, Mike Stewart and crew at Bark River obviously know what they are doing when it comes to edge/blade geometry and hardness in the steels they are using. I could not tell a bit of difference in edge retention between the A2 models and the CPM-3V models. Now I am sure if I was using them to clean game it would be apparent how much better edge retention the 3V has, but in wood, hard or soft, I can't tell any difference.
Anyway, I hope this info helps someone making decisions about bushcraft/outdoors knives!
