Some Information About the Folder!
Daniel Fairly Knives
Full Time Knifemaker
Moderator
I'm still working out some small details but here is a bit of information!
Steel - .227" CPM D2 Stock
This is the Crucible Particle Metallurgy (CPM) version of D2 steel. The CPM process essentially refines and improves the steel. I'm starting with .227" thick stock, it will wind up just a bit thinner after sanding to perfection! The steel is made in the USA.
I chose CPM D2 as I feel it has a great combination of edge holding, toughness and rust resistance. It is nearly stainless, tough because it is a tool steel and holds an edge like crazy.
From Crucibles Site:
Conventionally produced high alloy steels are prone to alloy segregation during solidification. Regardless of the amount of subsequent mill processing, non-uniform clusters of carbides persist as remnants of the as-cast microstructure. This alloy segregation can detrimentally affect tool fabrication and performance.
CPM steels are HIP consolidated from tiny powder particles, each having uniform composition and a uniform distribution of fine carbides. Because there is no alloy segregation in the powder particles themselves, there is no alloy segregation in the resultant compact. The uniform distribution of fine carbides also prevents grain growth, so that the resultant microstructure is fine grained.
Advantages of CPM
For the End User:
• Higher Alloy Grades Available
• Improved Wear Resistance
• Improved Toughness (less chipping)
• Consistent Tool Performance
• Good Grindability (on resharpening)
Framelock Construction with .190" Thick Titanium Frames
I chose 6al4V Titanium for the frames as I feel it is the very best material I can possibly use.
The lock will be carbidized with 72 Rockwell hardness Tungsten Carbide. I will do this to prevent wear and provide smooth lockup and release.
Hardware
The biggest in the industry!
I'm planning on a 1/4" hardened stainless steel stop pin as well as 1/4" standoff and the biggest pivot available! The pivot head is just under 1/2" with a 1/4" shaft made from hardened stainless steel as well.
I am proud to say that I built the knife around the biggest hardware components that I know of.
Phosphor Bronze will be used for the washers. I feel it is the best for washer material strength, long term durability and lack of friction.
Pocket Clip
Titanium Clip - Tip up Deep "low rider" Carry
I'm using a deep carry clip for the first few but may play around with the design on later folders.
Length
Total Length - 8.47"
Blade Length - 3.48"
Handle - 4.96"
These measurements will probably vary a bit as these are handmade. I'll be keeping everything as close to this as possible.
Finish
Stonewashed Blade
Stonewashed Frames
Polished Tip and Edge
Everything will be hand finished, rounded, chamfered and more. They will be at a very high level of finish but stonewashed and meant for use!
Grind
The grinds will vary! That is part of the fun. Check my prior work for examples. ...Chisel all the way of course! Count on a polished convex tip grind, a saber, a tanto style grind and more.
Harpoon tip and Spear point tips will be available at first as options with later tantos in both harpoon and regular.
Price and Availability
$475 To be paid upon or around completion.
I am likely going to keep the price the same all year and make sure everyone gets one. I was hoping to do a pre-buy but have decided to sell them on a first come first serve basis after everyone I have already talked to gets one. I feel this is the fairest way to do it.
This way I can keep the price as low as possible and everyone gets a knife.
Options
Harpoon Tip or Spear Point - same price either way
Frame Anodizing - I can do a lot from solid colors to fades and more... just talk to me and we'll decide on a price up $25 extra.
Full Bead Blast or Military Finish for no glare - no charge
Sterile Blade - no charge
Sorry if this is not the right time or place to ask, but do you have any idea of the logistics yet? How many made, when, price?
Love you ambition, and can't wait to see more.
Best of Luck.
Best of Luck.
Thanks, great questions!
I am buying the steel and Ti for a total of 32 knives. I'll probably have about 30 to sell from this first round. I'll order more materials before they sell out too!
Everything is coming in the mail now including a new mill and grinder. I should have a prototype made by the end of the month if everything goes smoothly. After that I am making them as my main focus so look out soon.
$475; we posted at the same time
Thanks and much appreciated.
Daniel,
I cannot wait to see one of these in person, the specs, materials and design are awesome. Keep up the great work and congrats on taking it to the next level!
Best,
TCS
Ok, I just took some money and set it aside today for one of these! I'm so stoked about this dude! I'm tired of Kevin making fun of me for not having a big beefy folder! I will show him who's boss...
-Xander
-Xander
Dude if Kevin is making fun of you that is it! :D
Thanks for the support and that is great to hear.
Holay Dayum!!! This is as close to my dream knife as anything I have ever seen! I am eagerly awaiting WIP pics! :D
You rock Daniel! :thumbup:
Soooooo we can only order one at a time : ) ? Hope you heal up quickly, and like everyone else I cannot wait to see the folders WIP etc. Will there ever be a 0.310" thick run?
If so i'd like to get on that list right now please. thanks.
-Xander
NANER NANER:p
Daniel,I will pay extra if you make mine 1mm thicker than Xanders:D
I better be down for one!! This is right up my alley!! Love the steel choice and the Ti!! You re not playin around!! :thumbup:
Much appreciated! Once I get everything in it's on!
:D maybe two
I can't wait to be over the flu and get to grinding!
There will eventually be a .315" blade, I hope to work some in later.
Thanks again!
NANER NANER:p
Yes I will. :D
Hey Daniel sending a PM.
Sounds good...
It has begun :eek::eek::eek::eek:
:cool:
Yep, brace yourself Daniel :D
:D
Ha, I bet I'm not the first. Daniel said he had answered 29 emails.
I am floored by the response! Plus I got behind in TX, we had limited bandwidth there on the farm.
Good to hear that!
SUBSCRIBED.
Would love one, but in the immortal words of Jerry Clower, "If good mules were going for a nickel apiece, all I could do is run up & down yelling, 'Ain't that cheap! Ain't that cheap'!"
I have zero doubt that this folder will be phenomenal.
