Alex Topfer
- May 1, 2019
Hi
I have a few metallurgy questions I haven't been able to find answers to.
1) where does the pattern in cable Damascus come from?
With, say, 1095/15n20 it due to the different alloying compounds giving different finishes with etching and polishing, but I would expect the cable to be roughly uniform. is it due to decarbonisation in the outside of the individual strands?
2) what exactly happens during normalisation to reduce grain size? the steel doesn't melt, so why would the crystal structure change in that way?
3) a dodgy heat treat results in less hardness, but can it still be just as brittle?
I heat treated a 1095 steel blade a while ago, which then broke when i was trying to bend out a slight bend in the tang/handle (yeah, bad move on that). Given 1095 with a backyard heat treat and ~200c (~400f) temper I had expected it to be more flexible. Grain at the fracture point looked ok, not too large. (Could be the temper being bad, lots of variables here)
Thank you
Thank you
