I'll report more after more use but right now I can say the fit and finish on the knife I received is remarkable (Thanks, Tom Berry!). When I try to examine it with the naked eye for any flaws not associated to a production knife classification I can't find any. Unlike the Michael Walker ZDP I had although the MW ZDP felt lighter due to a single liner. All in all, this knife appears to have similar build quality as a top of the line large Spyderco but scaled down in size. That isn't easy on a such a small knife. The screw construction makes this knife appear to be built like a mini brick *hit house. The pivot uses the same screw as the scale screws. I can't tell for sure if there are washers but there is a very thin gap between the liners and the tang so it appears there may be a very thin washer on each side. I can't confirm that without disassembly. There is a gap though so I'm inclined to believe there may be thin washers. The lockup is early and solid. It came in a mini Spyderco box with an Edgeucation sheet and the knife came in a small bubble wrap sleeve. Because of the "Balance" element of the closed design, I sometimes try to open it from the wrong end until you get used to which end the blade opens. The blade tip is toward the Spyder Bug etching so I orient the opening side by that. Oddly enough, this knife can be opened quite easily one handed and I have large hands because I'm a large man. The clip helps with this by giving your finger tips something to brace against while the thumb is opening the knife. You can't close it one handed very easily though. I can't at all because of the large hands. Your hand is just scrunching down too much to disengage the locking liner and manipulate the blade closed with one hand. The "hump" of the blade when the knife is opened really makes this little knife easy to grasp with large hands though. Your thumb naturally gravitates to that hump. No need for jimping in such a small knife as it isn't conducive to hard use when extra grip is needed because of its purpose and intended use. All edges on scales, liners, spine, etc are polished to an almost satin sheen. There is no remaining "punch out" roughness anywhere on this knife. It's not dehorned and really doesn't need to be because it's a small knife for casual carry and use. Well suited to removing "Irish Pennants" or opening boxes and mail. When gripped properly the control is almost surgical and there are more than one good way to grasp and use this knife because of the Kuhkri style design.
As stated in my earlier post, the Kuhkri style lends itself perfectly for a small knife. There is no doubt this knife is WAY overbuilt for it's size. With the superb build quality, the steel liners, etc, this knife could last a lifetime. The open construction is well suited to cleaning with lots of pocket time. Although it looks good and is fitted superbly, I'm not sure what the purpose of the lanyard tube is. It's not a super deep carry clip mount so grasping it from a pocket doesn't seem difficult although maybe a small loop for the pinky finger might help someone. The lanyard tube is not much more than an 1/8" in diameter. For me though, with the size of this knife, I don't see a need for a lanyard. Conversely, I really like the short lanyard that comes on the PPT because it makes extraction from the pocket so much easier because of the deep carry clip. The edge grinds are fantastic. Very thin edge grinds and even on both sides. Just lay the knife in your hand sideways, place your index finger in the choil and pinch the blade with your thumb somewhere near the Spyder Hole and you feel like you can do surgery with this knife. Like a scalpel. I believe sharpness is even more important with small knives than large (although all knives should be sharp!) because you want the edge to do all the work when you are cutting something. So make and keep this knife as sharp as you can. The knife came shaving sharp.
All in all, this is the best small knife I have ever held and operated. I really may keep it and historically I don't keep the small knives I buy. I buy them in my "search" for a good small knife but seldom keep them. Again, I belive this may be a keeper because of the Kuhkri style working very well in a small knife.
