Some odd things going on sharpening an endura in zdp 189
Hey guys . Found and old endura I haven't used in a awhile . It's the Saber grind and I'd thought itd be fun to zero grind/sharpen it .
Fast forward and I finally got the scratch pattern from the grind line to the edge .
I started out with a 220 diamond as well as a 220 beston just to get an idea how fast the different stones cut .
Anyway on my 220 stones I had a nice even scratch pattern from grind to edge.
I went up to my 320 stone refining the scratch pattern here's where things got interesting .
After the 320 I went to 800 and my uniform scratch pattern wasn't so uniform anymore . I have what looks like low spots in the grind mid way from grind to edge on one side that the 220 scratch pattern will not come out for lack of a better word.
My first thought was my stones were dished , so I changed to another 800 same problem,lapped my stones and nothing .even tried other stones I know are dead flat and still I can't hit the middle of the bevel on one side . One side is just fine and acts like it's supposed to .
Again I thought my stones just weren't flat . After a few stones ,as well as more lapping I'm thinking this isn't the case . Suggestions ?
I'm thinking I'm going to haft to go back to the 220 and grind off more steel on the one side . Again the grind is zeroed now though so when I put it on the stone I am getting a burr I just have a low spot in the steel
Should I just live with it and use it ?
Another possibility is the bevel pushed over a little on one side and now has a contact area like a micro hollowgrind. More likely on lower RC, but any steel thinned out enough at the bevel can have this happen. Assuming it isn't from a warp, the fix is to grind it back out.
If it doesn't effect the sharpness or use, I vote use it and work it out over time.
I think it is like a micro hollow grind . Wonder why the 220 will hit it but the 800 and 1000 grits won't . I can live with it rather than just keeping on grinding off good steel. A 220 grit edge with a clean apex is a hell of a slicer.I guess if it bothered me too much I could go to sandpaper and a softer backing to get the scratch pattern out but he'll I'm babbling I'll keep it as is.
The mud from the 220 would be large enough to "fill" the hollow, at least enough to frost the bottom of the hollow in a lapping action. Once you get to finer abrasive it can no longer quite reach.
Is also possible when it was initially sharpened was on a wheel and the hollow is still there to some extent. If its one you've owned a while I'd stick with the folded edge theory.
I've seen it before.
Interesting thing is the beston or bester 220 doesn't produce a mudd. It a very coarse stone almost looks like swiss cheese, CKTG had it but it's not there anymore but it's a great stone none the less.
I'm 99.99% sure it was a low spot when they ground the bevels. I went back to the stones but this time I went with diamonds .
Not too crazy about the deep scratches of coarser diamonds I just got the Ole standby 3x8 dias harp coarse. Bout 30 45 minutes got it even but now I have a scratch pattern above the grind line on the shallow side .
No big deal though I'm going to run it through the grits to get a mirror polish along the whole grind (my intentions to start with).
Anymore work I'll bring the grind up on both sides with a belt sander .
On another note this knife is now amazing . I've had my share of zdp 189 but it's all been in FFG spydercos .
Treating the Saber grind like a shanogi on a Japanese knife and sharpening out the secondary bevel transforms this knife .
Even at a 220 grit Waterstone finish it will push cut magazine paper completely vertical .
I wish spyderco would offer more zdp Saber grinds , except without the secondary bevel.
IIRC cliff stamp did a delica the way I did this endura and I believe he measured it at 6DPS if that can give anyone the sharpness level.
I've come across micro hollow grind edges before, but not on a Spyderco. My AL Mar ultralight came with bevels like that both sides, obviously cut on a wheel of some sort. The 10" wheel on my wet grinder makes a hollow bevel technically, but its nothing you'd notice sharpening by hand.
If the edge wasn't turned then there's only one other explanation, it came that way.
