Context: I'm thinking of getting into knife making, sort of as a side hobby. Not ready to spend thousands yet, but currently all the tools I'm purchasing total about $1250 which is about where I'm drawing the line.
Question 1: How can I control the temperature of the forge for HT? IIRC for preheat it's 1 hour of soaking per 1 inch. I'll be using 1/8 inch so just a few minutes of soaking. I'm going to make my first few knives out of O1 Tool Steel and a few out of AEB-L. For the stainless, I also need to austenitize for around 15 mins (or 5 mins at a slightly higher temp). This all brings me to the question... How can I hold the forge at a specific temperature to soak and austenitize?
Question 2: If I were to skip out on the preheat, would it make sense to grind my bevels post-HT to avoid warping?
Question 3: From what I understand, "Belt Grinders" and "Belt Sanders" are really the same thing, you just refer to it as what you are using it for and the type of belt. Is that correct? (and would a normal belt sander work fine for bevels?)
Question 4: What's a good HRC to aim for? (for a small pocket knife). My tempering time depends on it of course.
Question 5: I was thinking of getting some of those blue "Magnum" Sharpie's to use instead of the blue marking paint. Is this a viable option? (I don't know why they are called "magnum" either)
One more quick question: Any recommendations on type of glue to use to glue the paper sketch to the steel for cutting out? Or do you prefer just to trace it?
I'll probably have more questions to your responses in the thread but that's it for now.
Thanks for whatever insight y'all can give!
P.S. I'm quite new to knife making so don't mind me making tons of errors in the terminology.
