After years of thought and consideration, I've decided to make a serious personal effort in the world of knife making. since this is my first post here I'll give a little background. I'm 19, and a mechanical engineering major. along with other artful and technical things; knives have been a large part of my interests. now that i have the financial means, inspiration, and resolve to try a serious hand at it, i want to make knives and have a couple topics in question.
my first subject in question is forge construction. i really only need the forge to be useful for heat treating, and possibly forging blades no larger than 12 inches. because of this, a compressed air tank or 5 gallon paint can forge seems entirely inefficient. instead i have selected a relatively small forge body to build from. the vessel i selected is a section of some sort of industrial sised, flange ended pipe nipple i spent a lot of effort sifting through a construction site dumpster to get(it is damaged on the sealing faces). internal dimensions are 8" in diameter and 13" long. the sise is perfect. however i am unsure about a couple things.
first, i read on the zoller forge website that you need one 3/4 inch sidearm burner per 350cubic inches, does that refer to the sise of the forge body without insulation, or the inner dimensions of the insulated vessel?
second, my forge body is around 360ci without insulation and only 160ci with 2 inches of insulation. if i am in fact only going to be heating a 160ci forge, do i really need a 3/4" burner? i think a 1/2 inch burner might even be over kill. i haven't seen any 3/8" burners made as of yet but my question is: should i stick to the known 1/2 inch burner and turn the regulator down, or try to build a 3/8". my goal is temperature control so which do you think could be most precise for heat treating.
my other subject in question is steel choice. i have read all of the posts from kevin and think i have a somewhat serviceable, yet extremely basic understanding of steels. with this said, i have narrowed my choice to 1084 and 5160. whichever i pick, i will be using for a long time. for clear reasons, 1084 is a good choice for beginners. 5160 seems a little less recommended and i want to know why. essentially, within my parameters, can one steel make a markedly better blade compared to the other? it is my understanding that 1084 might have better edge holding capability. can 5160 match that capability and also carry better corrosion resistance and toughness? is 5160 a more worthwhile steel to use in the long run? perhaps i am over analyzing this. what are your thoughts? i have no idea why i am attracted to 5160.
in conclusion, i'm mostly just excited to finally be building a forge, and begin. thanks for any advice in advance,
Volta
Volta
