- Mar 20, 2016
I'm relatively new to CRKs as compared to some / most of you CRK subforum dwellers, so advance apologies for topics already discussed. Having said that, I also use the search feature somewhat extensively before I post threads in a willy nilly manner, although some fresh sharpening discussions can always be helpful as some folks may have found newer products or adopted new equipment and techniques.
I'm well aware that the Spyderco Sharpmaker is recommended by CRK and also many of you have that and use it. I have the Spyderco UF large ceramic plate which I have used for my Spyderco Millies plus stropping using Flexx strops green and then white (Flexx Strops uses Bark River products, green is for medium and white is for fine).
My understanding is that the secondary bevel on most CRKs from factory is convex and I wish to keep it that way till reprofiling is really necessary after longer / harder usage. In the meantime, I was thinking about acquiring the full array of Ken Schwartz formulated CBM emulsions from KME with their kangaroo leather strops. The cost factor being in the $135 range for a set including the 4 micron, 1.5, 0.5 and 0.1 plus 4 of those strop strips which are quite small. I understand this set up to be mainly intended for polishing an edge but I don't mind if the edges of my CRKs are not toothy, because I have plenty of toothy in my possession in other none CRK blades.
Now to the crux of the matter! What kind of experiences have you had with those CBN emulsions, if any? Overkill considering what I already have just to maintain an edge and making it a lot sharper than the factory sharpness out of the box?
Also as an aside, if / when I invest in a guided sharpening system, I was also thinking about a KME. Thoughts please?
