Some Southern Late Winter Survival Foraging
Mistwalker
I've spent the last several weeks gathering plant ID images for a few projects I'm working on, and I thought I'd share some thoughts and images of late winter foraging in the south.
Most of what was growing in the forest meadows back in the summer has now gone to seed and died back to it's roots. Most of it, being of hollow stalks, is much more suited to making bedding from, to insulate the body from the cold ground now. The deer certainly take advantage of it on sunny days. By flattening and area to lay in, the entire rest of the meadow blocks the wind and the depression traps the warmth of the sun.
The airborne seed pods of the goldenrod and thistle make a great flash tinder, that when dry will easily take the sparks from an EDC ferro rod and flash hot enough to ignite the grass leaves and then the hollow oxygen rich grass stalks, and then the pithy oygen rich golden rod stalks in a chain reaction that more than plenty hot enough to ignite the "toothpick, pencil, finger" sized twigs in a fire lay.
But when we look down on the grown between the dried stalks, we can see onions growing through the lifeless detritus.
On warmer sunny winter days we can even find dandelions popping up there as well. The dandelion rosettes are there all winter, but they are not always easy to spot. Dnadelions are both nutrituous and medicinal
End part 1 of 3
And some things that look like dandelions also, wild lettuce, because they are in the same plant family as dandelions, but a different genus. The wild lettuce is more medicinal than edible.
Dandelion on the lower left, furthest from the knife and wild lettuce on the right. The look a lot alike from the top.
Dandelion leaves have round essentially hairless stems
Wild lettuce leaves have triangular stems with hairs on them, and is sometimes called prickly lettuce
The balls on some of the goldenrod stalks are galls, and contain insect larvae, in a pinch they could be used as fish bait. The birds sure like them.
More larvae can be found in some black walnuts
Then there are other signs of life to be seen
End Part 2 of 3
We have a lot of briers here. I've learned that with a pinkie lanyard on a knife this size I can safely hold it in a two-finger-grip and just snap-cut through any briers in my way without having to carry a larger cutting tool for that purpose.
There will be more emerging as we enter spring. The creation we live in is such an amazing place.
