Some Spyderco knives and impressions.
1st allow me to talk about the new Native model. I say new, because it has the cut out on the lockback release. It works very well. I had my doubts when I first saw pics of this feature. I thought it would make the lockback difficult to unlock. Well I was wrong, sure it takes a little more pressure but it works very well, and if it helps prevent and accidental release thats cool as well.
The fit and finish on the Native quite surprised me! Very little blade play (this is a FRN rivited model so some is bound to be apparent), and its rock soldid up and down. The FRN handle is very comfortable in the grip and the clip works well as ever. I am surprised at the blade length. In the UK an edge or blade length is measured by the actual edge not the total length of the blade. Thus I was pleasantly surprised to find that the Native is slightly shorter in actual cutting edge than my new Delica. This puts it under 3". Now I know in the UK if it has a lock the size does not matter by the letter of the law. But let me tell you this, if it is less than 3" you get a lot less grief over any knife.
The edge is very sharp (as ever) and is that rather nifty CPM440V, which I am sure you may have heard about . On this steel, I resharpened one of my Military blades using the Spyderco Ultra Fine Benchstone to 15deg per side and found some interesting things. Firstly CPM440V takes a very different feeling edge, it is very very sharp but strangly not as sharp as my CRK&T Kasper in 6m (same angle same stone). The Military shaves nicely, yet the 6m Kasper pops hair! This made me think I was doing something wrong, but I think it has something to do with the fact that the Vanadium carbides are not being cut well by the ceramic stone. The Military is still down right scary sharp, but not quite what I expected. I did spend a good hour making sure the edge was symetrical. It is one of the few knives, that when I test the edge with my thumb, removes a layer of skin with the slightest touch! Strangly the edge feels a lot sharper after testing it on some free hanging paper? Weird but wonderfull stuff this CPM440V!
On sharpness, let me talk about the Blue Delica, OMFG! This is the SHARPEST knife I have ever seen out of a box! Even my Sebenza can't match this baby. It is hair popping sharp out of the box, the grind lines are perfection and the blade has a very nice high polished finish. I never seemed to find a reason in the past to get a Delica, I owned the Endura 98 (serrated) and always went for a non-FRN model. However the Blue colour is very very nice, it really does make this look less threatening. Which is just as well when you see how sharp this baby is! The tip is hypodermic needle fine and sharp. I would advise potential owners of this knife to be careful with the tip, on testing the tip by pressing with a TINY amount of pressure into my open palm (I always do this to test sharpness of tip) i pricked myself right away! This is the first knife to EVER do this! However as the tip is very very fine and sharp I would not use it for prying as it looks like it would break very easily. I notice that the clip well is deeper on this knife as well, probably to stop it slipping, though I have not had this problem before. The lock up of this knife, like the Native is rock solid, unlike the Native, the Delica is very smooth, the Native feels a little tight. This does not worry me however as experience with my Endura shows the FRN does give a little after a fair bit of use.
All in all I expected the Native FRN to leave the Blue Delica in the shade after all I prefer the blade steel, shape, style and handle of the Native. However for some wierd reason the Blue Delica has a strange draw that I have not had with a knife for a long long time. I can't stop playig with it! I am very pleased with both, oh and the Starmate I have just got is quite nice as well
A word on the Starmate, nice knife but... I don't know why, but I expected more for some reason. Nothing wrong with it (appart from a vertical scratch near the tip), it just did not set me on fire. I think I am so pleased with the two FRN models I have not had time to give the Starmate a good playing with!
All the Spyderco blades are perfectly centred and sharp as heck, the Delica being stupidly sharp. I would like to know what grit or ceramic type grit these blades are finished on, they feel more grabby than a Ultra stone polished edge, but seem to shave just as well.
CPM440V has a weird grain quality to it as well, it just feels very different to normal steel . I think the Vanadium carbides are acting like little teeth and as they are so hard and there is so many of them in the matrix, then I need to start using a diamond hone to get that popping edge back! Still like you said, its a bit like having a chainsaw! Cool! I don't think the hair popping quality is something to worry about though, I think as this kind of edge is dependent on a type of 'wire' edge forming (which confuses me a little as a wire edge is a bad thing? Perhaps we are confusing wire with burr?)well I just don't think it is possible to form this wire edge as well with this steel. My uneducated and probably dumb thinking is that with a plain old carbon steel, the matrix is the edge (by matrix I refer to the material that carries the Vanadium or Tungsten carbides etc) There is not complex make up or special carbides in a plain old carbon steel, not even Chromiuim carbides! Thus all you have is the steel and it wears at a prety uniform rate. However with a material like CPM 440V I think the steel part of the blade wears more than the Vanadium carbides, and what we are seeing is the Vanadium carbides sticking up and out of the steel. This gives a micro serration effect, even when sharpened on a very very fine stone. I found that with a little cutting work on mear paper (say 20 slices) the edge felt FAR more grabby and sharp. Yet it had lost a fair bit of its super shaving edge, it still wouls shave, but not as well. I think the Spyderco 204 and Ultra stone are polishing the Vanadium carbides, and after a little use they are rough and acting like a mini chainsaw! Now I am probably wrong on this, but I have noticed in the past that CPM 440V holds a great toothy edge a massive length of time, it cuts and cuts and well cuts! It also feels a lot sharper to the thumb on edge test, but wont shave very well at all. As I said above I thought it was my sharpening skills at fault, and lets be honest, CPM440V does take a bit of practice to get a perfect edge on it! It is so wear resistant it is unreal, must be a total bear to grind. I own 4 blades now in CPM 440V all from spyderco. The other thought was that the relativly low Rc level on these blades (55-57?) might move the very fragile wire edge back and forth, thus stopping it being a great push shaver/hair popping steel? But then again I am probable wrong here as well.
As a final test, last night I held up a free hanging bit of A4 paper that I use at Uni for my work. I then cut 705 of a perfect circle in the paper and only had to stop as the thick spine of the blade got in the way as I turned the knife through the material. Now correct me if I am wrong, but any knife that can cut through paper this cleanly with almost no pressure is a sick and frightening edge? One of these days, I will slip with a knife like this and cut my hand off! Scary sharp!
Spadeworx, the Blue Delica is indeed a very fine knife. I don't know what it is about the colour, but it does seem far less threatening. I asked some friends a day ago to look at three small pocket knives I had on me, they were
1. Blue Delica plain edge ploished blade ATS-55
2. Mini AFCK plain edge, black blade M2 steel
3. Camillus EDC DDR 154CM Stone wash plain edge.
Now to be honest, the lads all went right for the EDC and the AFCK, the little blue Delica was picked up by one lad with a look of 'ah so I get stuck with this one?'. Simple fact was most looked at the blue Delica and then put it down to see when the could have a go with one of the others. Only one person tested the edge on the Delica, while everyone else was running about looking for things to cut! (well not quite that bad, but I brought some paper and bits for them to cut up). When my friend saw the edge on the Delica, the look on his face was a picture! His eyes bugged right out of his face and he gave me a look as if to say 'you bastard!' He put it down and spent a couple of mins playing with his finger waiting to see if it would start bleeding... It did not as it happens, but it gave him a shock! I must note I did warn everyone before I started that the blades were near enough razor sharp and be careful!
The general consensus was that the AFCK was the one they most wanted to buy. They said it looked the most high tech and cool. The EDC came a fairly close second. Half of the group did not like the cut out hole design or the thumb stud (all prefered the Spyderhole on the other blades). They also thought the blade finish on the EDC looked crap and the blade was too heavy for its size! Just goes to show what non-knifenuts know
The Delica was described as nice and sharp, they liked the edge and the hole, but saw the blue colour as a turn off. Now, remember these are all youngish lads (all 18 and above, but students ) and they wanted the most macho blade I had. However this highly scientific test shows to me that the Delica does what it does, perfectly! It is a tactical blade, that does not LOOK tactical, it is the right size and that blue makes it look like a fun/womans knife! Sorry Sal! Now I personly dissagree with the colour looking 'girlish' as one of my friends said, but if that makes this deadly sharp knife an accepable thing for most sheeple, then how about a blue handled Civilian Sal?
God, I love that little knife!
All in all, typical Spyderco knives. Well made, great value and desirable as hell.
All I need now is... Well you know I want a mini Military, but how about a Blue Endura?
Thanks Sal!
Wayne.
"To strive to seek to find and not to yield"
Tennyson
Ranger motto
A few useful details on UK laws and some nice reviews!
http://members.aol.com/knivesuk/
Certified steel snob!
General,
I have encountered the same 'feel' with BG-42, maybe not to the same extent - cuts like hell, but doesn't feel as sharp. Vanadium might be the reason you say? I am extremely pleased with BG-42 but it looks like I will have to search out a CPM440V blade.
Thanks for the review!
Steve-O
General,
Nice review. I own a few knives in 440V and I kept on complaining about how hard they are to sharpen. Then I got a custom Darrel Ralph EDC in 420V. Compared to 420V, 440V is a joy to sharpen!
I don't suffer from insanity ... I enjoy every moment of it
General,
I have a Delica and I agree; it does have a lot of appeal and character in addition to it's performance. Mine had a rock solid lockup out of the box with no blade play in any direction and it is still that way.
Maybe I'll get a blue one, I like the color.
Ron
Great review General!
For many, many years I shunned Spydercos. I guess the hole was hard to accept and I had a misconception about knives "made in Japan".
I carried my Schrade LB7 and told my friends "No way am I going to carry a lousy plastic Japanese POS like that".
Well, I have eaten those words by the plate-full!
Now, I am a Spyderco convert in the biggest way.
Allen, I used to feel that way about Spydercos too. I still don't get all that excited just by looking at them, but when I got my Calypso Jr. Lt. in VG-10 and encountered that unbelievable edge geometry and cutting performance, I modified my opinion somewhat. More traditional styles still give me a warm feeling, but I have learned to appreciate the Spydies for what they are--trmendous users. Great review, General.
Thank you for the kind comments gentlemen!
Wayne.
Tennyson
Ranger motto
Spyderco was certainly among the first to set a high standard for quality in production knives. I own a mere 5 spyderco knives, including the "spyder card", and every one of them was beautifully sharpened right out of the box with even grind lines. Blades locked up tight, and for the most part still do even though two of those spyderco's go all the way back to being my oldest one-hand-opening knives. My Delica is now almost 6 years old and in my wife's posession, a woman who does not baby a knife!
I am with you all the way on the Delica. I've never held a blue one, but I imagine the only difference is color. It's the only knife I've ever owned with a 50/50 serrated/plain blade combo. I know logically that should be too short a length for a serrated edge to be very practical, but forget the logic--I found that a great multipurpose combination.
General, Curious...have you used your Starmate yet? I just picked one up the other day and so far I am nothing but impressed with it. Seems like folks either really like it or don't. I chose it over the BM 710...Ed.
Why yes...
It is my current EDC. Heck of a knife, the more I use it the more I like it! I will update once I have the time!
Cheers!
General,
I thoroughly enjoted your review of these Spyderco's. I have just recently posed a question to the Spyderco forum about suggestions for my choice of serrated vs. plain edge blade styles in a Military model that I intend to purchase soon.
If the CPM440V steel seems to develop an apparent micro serration effect from normal sharpening efforts, it makes my decision easy to go with a plain edge in this knife. This knife should be the best of both worlds, sounds like.
Thanks again for the great review. Jeff/1911.
Nice work Wayne!
I also have noticed that CPM 440V blades - Military for example - do not feel as sharp as ATS-34 or 154CM counterparts and cut hemp rope or wood less aggressively. Especially being finished on Ultra Fine SPYDERCO ceramics.
However I could discus the reasons of this effect. In my opinion this is due to extremely uniform structure of CPM 440V and relatively low hardness. Being finished on ultra fine whetstone it cuts like very sharp blade should cut. On the other hand quite brittle ATS-34 and 154CM, even sharpened on ultra fine ceramics, display continuous micro chipping when cutting and due to this cut more aggressively and seem to be sharper than they really are.
Please note that no one SPYDERCO knife has out of the box highly polished edge but they cut like crazy!
Good reveiw General, I have the same impressions of our blue Delica. I'll be glade when I have the money to try the 440V Native /Starmate! RKBA!
when all these people line up to say I did something right, all I can say is thank you very much friends!
. All I wanted to do was tell someone else, how much I have enjoyed my Spyderco knives and hope I could help out. I am never going to be a big time knife guru like you Sergiusz, but I am very grateful for you kind comments. Was the info about the SA-80 any use BTW?
All the best,
Wayne.
Tennyson
Ranger motto
