man those ubers are quiet. i like that. i wonder how much the motor and vfd are. those run off air correct?Double wheel grinders to grind hollow grinds are used in industry, but are a bit too complex for most hobbyist. You would be far better to build an uber-grinder with water cooled belts.
Hard grinding wheels are also used in industry, but require different types of grinders and total flood coolant. Again, a good grinder with a water cooled belt setup would do as good or better for most knifemaking. CBN wheels are for grinding hard and small things like carbide tooling. It would be a poor choice for knifemaking.
that was lewis. he caused me to make a straight razor a couple weeks ago. if you never shaved with one i suggest trying it. no more razor burn at all, and its pretty cool shaving with something you made yourself. i done went crazy and got a 60$ shave brush, a stand, 2 soap cups, and about 5 different soaps. lol im hooked.One of the custom razor makers used to use a home made version of one of those IIRC. I seem to remember that he switched to just doing freehand on a wheel.
Yea im going the water jet route for about 4 different models in going to make. I was going to buy a plasma cutter but a local shop is going to cut them from 1-2$ a blank. Cant beat that. Min 20 per pattern. And said if i need to throw a one off in there every now and then that's ok to as long as provide the cad file.Hard grinding or CBN wheel grinding with flood coolant is usually a CNC based process, where visibility is not a concern. If you're just hand grinding, you'd be better off with a water cooled platen or a mist coolant system. As for the double wheel machines, I think they're more of a gimmick than anything. I don't know of any well known/established makers that use a double wheel set up, and there are probably many other well spent ways to gain efficiency. Have your blanks waterjet, hire a person or two (or three), etc....
Just my $.02.
it would have to be super heavy, but it could be done pretty easy. stafferieo "that's probably not spelled correctly" but they have a decent looking build of the double grinder. theirs doesn't turn tho. basically build it on a couple x, y, tables with one or both on a turntable.I was talking to Travis Wuertz, after BladeShow last year. I mentioned that it would be great to fabricate a two-grinder work station in such a way that the grinders could pivot toward each other, with one on a track for fine adjustment to get the gap right. His eyebrow raised with a sinister grin... but we were pretty full of imagination fluid at the time. It would be cool to sit and think on that, sober.
