- Oct 19, 1999
I plan to do a 'history lesson' on weehawks sometime when I get my other knvies back.. but I noticed somethign quite peculiar with BM45's.. the older the BM45 (in production date) the nearer the elastic band on the sheath is to tbe bottom.. the newer set of sheaths seem to move up (as on my sheath page)
I also noticedanother thing. The older the production the more inconsistent the grind is on the swedge. It makes it seem that the newer ones are machien ground and the older ones are hand ground??
and the kicker.. if you look at the side of the blade WIHTOT THE butterfly.. that is where it says benchmade, run your fingers on he unground steel. Is it smooth? r is it 'ribbed' like a cheese grater?
it seems that the older production of BM45's havea smooth finish on both sides, while the newer ones have a rough surface. Just horizontal lines from the npolished stel.. INteresting.
<A HREF="http://www.contrib.andrew.cmu.edu/~soo/balisong/balisong.html" TARGET=_blank>http://www.contrib.andrew.cmu.edu/~soo/balisong/balisong.html
</A> If you play with love you will be heartbroken; if you play with knives you will [bleed]
