Something bigger than a Spyderco Mule S90V?
Hi All,
I have been using my Mule an awful lot and love it to bits but am after more blade length in the same style of knife.
I can't get over this S90V steel, it blows away everything else I've used, even M4, S35V, CTS-XHP, 3V etc. The S90V just stays sharper longer.
Apart from the steel, I love the blade of the Mule, 3mm thick blade, full flat grind and lots of distal taper.
The Mule is a pretty flat blade shape with not much belly, could almost be a modified whatncliffe blade shape, which I love. I love the way it slices and never gets wedged in anything.
It's 3 and 5/16" long, and I'm after something over 5 or 6 inches with a similar thin blade and preferably in S90V!
Is there anything like that out there?
Thanks, Steve.
My Mule:
Bladeforums member Jaabel put on a maroon micarta handle and made a kydex sheath for it. He's a great guy and the work is flawless, I can't fault the job he did at all, I love it.
what will the knife be used for? you're most likely going to have to find a custom maker to the knife you want.
Mainly food to be honest it's nice to have a longer knife to get all the way through a melon or something in 1 slice.
Not just food though of course, or I'd use a food knife, of which I have plenty.
I like the Mule as it's strong near the heel, but thin near the tip. Perfect geometry for the every day tasks I do and I want that same geometry in a longer blade.
Not sure which custom makers can do that.
I don't use it, and wouldn't use the knife I'm wanting, to split or carve wood, chop anything, touch bone (hopefully...) or to pry with.
It will also see a great deal of cardboard, some light gardening/pruning green branches/vines, cutting hoses, ropes, pallet wrap and packing materials. I also want to be able to cut up cakes and things with it at morning tea, I need to do that most days :)
I would carry it like I do the Mule, always in my day bag or if I'm home, on my belt.
You should email Phil Wilson. :thumbup:
Here is his website.
http://www.seamountknifeworks.com/
Thanks Jim, believe it or not I've been reading about Phil for that last hour! I was given his name soon after starting this thread (thanks ;) ) and I think you're right, I'll get in touch with him as soon as I figure out just what to ask for :)
Anytime. :)
I am sure he can do something for you. :)
