I don't think one could answer that definitively. Even with certain knife designs, the hole or the thumb stud doesn't always facilitate effecient opening.
But as a guess, it would depend on the location, size, and depth of the etch.
What about a Swoop?
Something like a machined ledge, shelf, angle.... maybe even Acute.
Granted, the initial stock material thickness would need to compensate for this. Lots of machining. Wasted material.
And would likely need to be right hand or left handed.... Or Chevron -T shaped, If it was ambidextrous
There are thumb discs that can be added on to the spine? Maybe something like that? Or do you not want anything protruding from the side of the blade at all?
Lockbacks have the spring tension on them, so they need more help opening that say a crossbar, button, liner or frame lock would.
Thank you all for your guidance. I understand that the Lockback has a stronger spring than other lock styles. However, I would still like to try it on a piece of mild steel to see if it works.
I am not against a raised thumb stud or disc, I was just looking for something different and unique.
I also like the idea of a Swoop, as Crag the Brewer mentioned. Perhaps this could be added to the blade with two screws instead of grinding it out. I'll have to test that out in mild steel too.
