I have been working on a cheap gas powered weedeater. Trying to polish a turd is what I feel like I am doing but anyway. It had one of those little blades on the grass guard to cut the trimmer line to the correct length. I got out the belt sander and established some bevels/raised a small burr. And I do mean small. Then I took a extra fine diamond file and knocked the burr off. A quick strop on white compound and I bet the blade would have popped hairs. I didn't check though, it should have been sharp enough. I bolted it back on and fired up the weedeater. I let it run at full throttle a couple of seconds to get the line up to speed. I checked it and I could see the start of a cut. But no cut off line. I went back and forth a couple times but I couldn't get a cut line. Frustrated, I grabbed a fine file and took the apex right off that blade. I fired up the weedeater one more time and... IT WORKED! Freshly cut line from a dull edge. After I thought about it, I seem to remember a story about a paper cutting machine that required a squared off apex. Anyway, it was an interesting experience and a testament to matching your edge to the job at hand!
