- Dec 4, 2001
I don't know if it's just the allergies, or I'm haveing bad luck, or getting all mysticl..., but ever have one of those knives?
Just got done putting second handle and third gaurd on a knife, after reprofileing the point. Seems this one was insistant on how it wanted to come out, no matter how I tried to change her. First tried a bronze gaurd, could not solder it for the life of me(have soldered bronze from the same block befor, no problem) Then a nickle silver gaurd soldered perfectly, and decided to use a nice piece of stabilized box elder crotch, but on shapeing I ground to much of the wood away at the gaurd, didn't get into the glue channel or tang, but handle was 'off', too small. So I knocked the wood off, and since the gaurd was too small on the underside, knocked it off too.
Well, while fitting the new gaurd I managed to chip out a dime sized section of the edge. I normaly seat the gaurd by driveing in on with a spilt pice of wood and a hammer, driving the blade into a block of hard wood. This time I did it into my bench, and cut a nail in two. So off to the grinder I went to slightly shorten and reprofile the front of the blade. After all this I decided on goat and buffalo horn handle, and everything seems to have gone right. Will know tomorrow when I profile the handle and hopfully finish it.
If it dosn't work this time the blade is getting a bend test in the vise! I would probly have already destoryed the knife, but there's something about it,...
