I used Talonite in the past and was very disappointed with the cutting results when used in the field and without trying to cut bones etc. to destroy it. It just wasn't a good field knife.
Frank.
Stellite/talonite. The stuff will cut and cut and cut, but the material is relatively "soft" compared even to the cheap steel knives. It makes an okay folding knife for light duty tasks, where corrosion resistance and low magnetic signature is a big factor, but there are better materials out there. If you hit anything hard, as has been pointed out, the edge will deform. It will cut soft and fibrous materials well, like cardboard and rope.
The way stellite works is it relies on carbides imbedded in a soft cobalt matrix to cut, essentially as you use it the softer cobalt wears away exposing more tungsten carbides, and it will keep on cutting long past what feels dull.
I have made two folders with the material, I will not work with it again. Solid carbide tooling and a very rigid set up for even making a simple hole, it can not be cut with a band saw, or hacksaw, it does grind easy enough and requires no heat treat. To put it in perspective, the teeth on high grade metal cutting band saws are often bonded stellite, so essentially you are trying to cut material with the same material.
The other factor is cost and, as you have found, availability. Save the headache, use a different material.
The Bybees (Jon, Chuck and Jessica over at Alpha Knife supply) did introduce me to a very cool nitrogen blade steel that is essentially corrosion proof with low carbon, that performs at about the level of the good ol' 52100 steel. Stuff is called ZFiNit. Interesting stuff for sure. I sent my blades to Peters for heat treat.
