South Paw 52100 Gents Frame Lock
STR
Knifemaker/Moderator
Moderator
I had more pics but the sun is getting harder to find and I was shakin' so the majority of the good angles I got are no good since they are blurry.
Anyway, these show it pretty good I think. The one has a bit of glare but I was trying to get a blade center shot. I think you can see that ok.
Yet another Ouparator frame lock. I don't think its half bad for the first lefty I've done in a number of years. The Ray Kirk ABS MS 52100 blade makes it that much better IMO.
Thanks for looking .
STR
Another beauty, Steve. How many parts does this knife have? Is there a detent?
Detents are installed yes. Otherwise it would end up opening in the pocket and qualify as a gravity knife and you don't want to be selling those. Detents are a must really. They also end up helping the action a bit. I use 1/16" diameter 440C ball bearing.
This design of this folder is very simple. First and foremost its an all screw construction. The idea here is for a simple easily taken down, maintainance free light weight EDC, although I never recommend taking them apart unless you need to. Now of course with the carbon blade its not going to be quite as maintainance free as the stainless blade ones but being able to break it down easily is a big plus for cleaning it to visually check it for spotting or any signs of grit.
Construction is quite simple. Again the idea is to "KIS". (Keep it simple) I'm really just a country bloke that is not all that complicated so my knives end up a lot like me.
Some models vary. My own is even less complex than Thom's here. In Thoms there are four barrels, 8 screws, a thumb stud and screw, a blade and two teflon washers and a .070 thick 6AL-4V titanium lock and liner with a detent on the lock, and a low rider pocket clip with two screws.
On my own its just two barrels, one for the pivot, one for the stop and then for the rear I just threaded the lock side and used two longer screws to pull it together tight. Other than this its the same though.
The platform this model gives me to work from allows me to offer it as a base model like seen here, as well as doll it up with scales, or bolsters and scales if I want to or someone ordered it that way but this right here is the one everyone buys. However, it does lend itself well to mods later also which I think people like. If you notice on Thom's I didn't bevel the edges a lot and its chunky compared to mine so he can have someone pimp it out if he desires and the screws and all the chunky build will allow him to still sand all the new additions flush without worry of getting too close to the heads of the button screws. I left him plenty of playground to mess with in other words.
Thats it. A simple straight forward little folder. In many ways it is kind of like a lighter duty smaller Sebbie only with a Wharncliff blade which is all I make. I love them!
Thanks for asking.
STR
So I've just started carrying this Rice/Kirk Ouperator and it's oozing with good features:
Wharncliffe blade in real steel
Choil/integral guard
STR Low-Rider pocketclip
Slim profile
Unobtrusive thumbstud
Edge (about 0.012" thick at shoulders) that's just thick enough for tough cutting chores and just thin enough to enjoy them
This knife not only sharpens right up using circular passes of a ceramic over its edge, it seems to prefer it to waterstone fun (and being that it's folder with a non-stainless blade, that's always a plus).
When it has seen more use, more will be written.
Thanks Thom. I just started using those thumb studs and I like them better personally than the knurled ones I still have a bunch of even if these new ones are five times higher priced.
The knurled ones work fine but they could sometimes peel a bit of thumb skin and required additional tweaking which bothered me and some users so once they are gone I figure I'll stick with these.
STR
10 days since talking about this knife.
I really like its slim profile (handle and blade). Either clipped or on the bottom of the pocket, it's unnoticeable until you think "Man! I really need a Rice/Kirk Ouparator for some snipping" and there it is. Generally not a titanium lock fan, especially since stainless steel is harder (learned that when STR lent me his Kershaw framelocks :cool: ), but it's a vault on this knife and feels grippy against the skin. Finally got the hang of sharpening pocketknives back and the Ouparator just took a pleasing edge with a Spyderco DoubleStuff.
Hoping that STR and raker will collaborate on more projects in the future.
I am glad you are liking it Thom. I sure love mine!
Haven't heard back from Mr. Vu about the one he won in the give away.
I thought with the Krien ZDP Jess Horn blade and my new ti conversion of that one that it would bump this little Raker blade out of my pocket and it did for a day or so but its back because I missed the little gem.
Its hard not to love this little blade. Ray does a stand up job with this steel no doubt about it.
STR
