- Oct 19, 2005
Folks, I'm having trouble with the Spa Service. What I'm finding is that used knives are getting sent in to have end user customizations removed or undone. Examples range from patina's to re-grinds, or buffed blades that have to be re ground. There is only one way to get off a patina. I have to take the knife back to the grinder and re-grind the bevels. BUT, at least the ht isn't questionable just because of the patina. The buffing and re-grinding are a problem because I can't guarantee the edge of a knife where this is the case. If you are buying a patina'd knife, please make sure you like that patina. If the knife has been re-ground with a tool, I cannot and will not guarantee the edge of that knife. Neither of these instances are what the spa service was meant for. Specifically, it was meant to clean up a knife you have used hard. A Re-touching of the edge, a re-sanding of the handle, and a re-mark.
From here forward, the spa service will begin at $50. This covers the re-sanding, re-marking and re-edging of the knife. Other services will add additional costs.
