Buck's Spa treat does include polishing of the handles scales or they can be replaced for $15.00 if they are too far gone.Quick question for everyone. I've sent about a dozen knives in for spa treatments and Buck has done an amazing job. I have a 110 that has faded out/dry scales. Does the spa treatment do anything to the scales to bring them back to life??
Thanks for the reply!If they are dymalux or dymawood laminates, the dry or faded out look is when the resins are getting broken down either from sunlight or chemical reaction. I had a knife handle like that and I lightly used a 620 grit sand paper to remove the dead stuff and then some 1200 grit and then buffed it to a shine. I had been washing it with a disinfectant soap and found out it had VOC solvent that was affecting the resins. After that I used ordinary dish soap and rinse and it still looks good as new. Sitting in the sunlight a long time the uv rays will fade the resins too. Avoid solvents or VOCs is the main and most common problems with laminate resins.
So if the damage isn’t to deep the spa treatment should get them back to looking new again.
Can buck regrind a blade and remove the laser etching View attachment 1197683View attachment 1197684
It’s very lite I’m not going to sand on it myself
Update yesCan buck regrind a blade and remove the laser etching View attachment 1197683View attachment 1197684
