- Mar 7, 2000
So I'm about to put handles on a blade and I'm running into a problem. The Micarta I'm using is warped. Trying to flatten it on my Sears belt sander is giving me fits because the platen is too small. I was able to carefully do it on the disk sander (a trick in itself), but now I'm seeing that the steel itself isn't perfectly even. I'm still seeing light between handle slabs and the tang.
I've never used spacer material, but it strikes me as a viable option to get a tight fit. From what I understand, it's a thin sheet of (foam?) rubber. Is that right? I've seen a similar product in the craft stores- something like rubber paper. Would this work? Also, any suggestions on the handle problem in general is appreciated.
Thanks...
Thanks...
