I’d stay away from them, no reason for a cheap generic 36 grit ceramic belt to be $20. Here are some reputable belt suppliers that I typically order from, Popsknifesupply, Tru-grit, Brodbeck ironworks (local to me so easy to pick up belts) I like some of the VSM line belts like the actirox line for 36grit, 880 and 885 line for ceramics. For handles I use zirconia belts in low grits with a stiff backing and flexible aluminum oxide belts in 120-600 grits. Norton blaze belts are also really good ceramic belts, and if you grind at really high speeds 6000-8000 sfpm and high pressure then 3m cubitron belts are really good but can be pricey and don’t last long if you grind at slower speeds or freehand.
